Kunena 6.4.7 Released
The Kunena team has announce the arrival of Kunena 6.4.7[K 6.4.7] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
Sticky Problems after upgrading to K6.1.3
2 years 2 months ago #41 by Gindi
ok, then leave it on "en".
In all previous Joomla versions there is "en" in it.
Maybe someone tested for 6.1.3 with the Dutch language and changed there the "en" to "nl" and forgot to undo it.
For me it also works with "nl" in the ckeditor.js, but does the CKEditor speak with you now also in Dutch after the change in the ckeditor.js?
Gindi
2 years 2 months ago #42 by Leen
Hello Gindi,
You did give me an idea in a test site
I have now named the original in kunena "oud_ckeditor.js".
and replaced from the downloaded version you suggested
CKEditor 4.19.0 "ckeditor.js"
And the special thing is that it works and also in Dutch
With kind regards
Leen
2 years 2 months ago #43 by Leen
forgot to mention that i also had to put the moono-lisa skin folder in l\media\kunena\core\js\skins\
With kind regards
Leen
2 years 2 months ago #44 by Gindi
Het is fijn dat het nu lokaal werkt.
gindi
2 years 2 months ago #45 by Leen
ha your answer is in Dutch did you do that on purpose?
With kind regards
Leen
2 years 2 months ago #46 by Gindi
Yes, a fun.
Gindi
2 years 2 months ago #47 by SIETWOLT
After updating to Kunena 6.1.3. it is not possible anymore to place content in the field Messages
2 years 2 months ago - 2 years 2 months ago #48 by rich
@SIETWOLT Post moved to this topic.
Quote from user Gindi :
To fix the problem, in the /media/kunena/core/js/ckeditor.js file, at the end of the file, change the last line "CKEDITOR.lang.languages={"nl":1};}()); " to "CKEDITOR.lang.languages={"en":1};}()); ".
After that the CKEditor works for the Dutch users
Last edit: 2 years 2 months ago by rich.
2 years 2 months ago #49 by xillibit
the K6.1.3.1 release : www.kunena.org/forum/76-Official-Announc...d-for-joomla-4-2-4-3 fixes the issue with Ckeditor
2 years 2 months ago - 2 years 2 months ago #50 by Leen
yes everything works as it should after the Update with version kunena 6.1.3.1 .
Can also respond normally to topics on the Kunena Forum.org
so this topic is now solved for me
With kind regards
Leen
Last edit: 2 years 2 months ago by Leen.
Time to create page: 0.260 seconds
