- Thank you received: 169
Kunena 6.4.7 Released
The Kunena team has announce the arrival of Kunena 6.4.7[K 6.4.7] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
Sticky Problems after upgrading to K6.1.3
The normal editor no longer works
can only respond with quick reply
With kind regards
Leen
it happened after the forum was updated to Version 6.1.13 2023-08-10
Have now set all Forum settings to default and cleared cache
Cookies etc also completely cleared but nothing helps.
Maybe this is from which country are you posting something?
With kind regards
Leen
even though I choose subject and for pictures with
then get this message
Cannot save message: Message body is empty!
With kind regards
Leen
Also downloaded and installed the latest kunena version again
but it remains that the CKeditor does not want to work only with the quick reply button I can reply to a message.
If I use the kunena template setting SCeditor then everything works okay
With kind regards
Leen
My national language is German, I use the CKEditor and so far I have no problems with K 6.1.3
Gindi
Unfortunately, that doesn't seem to be the case either.
Tried everything including language files etc.
Here in the Netherlands the CKeditor suddenly stopped working.
I've already tested it myself with turning off my virus protection etc
But do I do a clean install joomla and then with
Kunena 6.1.2 2023-07-08 then everything works fine again.
That's why I don't really get it anymore.
And it remains annoying that I can now only respond to this forum with the senl reply button, I can type text there
With kind regards
Leen
Today (Tuesday) I wanted to update the Lifesite backup from Friday in another test version on the local webserver from Kunena 6.1.2 to Kunena 6.1.3.
The update failed.
Warning
This extension does not provide a checksum to validate the integrity of the downloaded file.
Copy file failed
Package update: An error occurred while installing the extension: com_kunena_v6.1.3.zip
Before updating, check if it is compatible with the Joomla installation you are using.
It is strongly recommended to make a backup before the update.
danger
Error while updating package.
Although the update failed, Kunena 6.1.2 displayed the Aurelia template in version 6.1.3.
What changed from yesterday to today??
Gindi
Nothing has changed, it's still the same package on our download page.What changed from yesterday to today??
I have already tried everything, but cannot reproduce any of these errors.
But if I extract from pkg_kunena_v6.1.2_2023-07-08.zip the kunena_media_v6.1.2.zip on my PC and from there the \core\js\
the core\js\ckeditor.js and core\js\ckeditor_config.js
copy to the test site "\testkunenazes\media\kunena\core\js\"
then the editors work fine.
I must honestly say that I have tried the difference in this one
two versions to compare but I don't see that so quickly
but maybe someone with more knowledge of these two files will notice the difference
With kind regards
Leen
and in the version kunena_media_v6.1.2.zip this is the last line
"CKEDITOR.lang.languages={"en":1};}());"
And I can't really explain this both kunena version come
from the download page of the kunena forum
With kind regards
Leen
