Kunena 6.4.9 & Kunena 7.0.1 Released
The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question Problems after site upgrade to Joomla 4
2 years 9 months ago #227907 by rich
Ah... you are a new member. New users are not allowed to add links and attachments because too much spam has been posted.
Disable the plugin Kunena - Community Builder Integration and try to install Kunena over it again.
Afterwards test if the Forum works without the Community Builder.
2 years 9 months ago - 2 years 9 months ago #227910 by ProgAddicted
Done, nothing changed.
IMHO there is a problem with the DB; I tried to add a new category, it throws the following error:
1054 Unknown column ‘parentid’ in ‘where clause’
Call stack
<table>   <tr>     <th>#</th>     <th>Function</th>     <th>Location</th>   </tr>  <tr>     <td>1</td>      <td>()</td><td>JROOT/libraries/vendor/joomla/database/src/Mysqli/:141</td>   </tr> <tr> <td>2</td>     <td>Joomla\Database\Mysqli\MysqliStatement->__construct()</td>     <td>JROOT/libraries/vendor/joomla/database/src/Mysqli/:1048</td> </tr> <tr> <td>3</td>     <td>Joomla\Database\Mysqli\MysqliDriver->prepareStatement()</td>     <td>JROOT/libraries/vendor/joomla/database/src/:1900</td> </tr> <tr> <td>4</td>     <td>Joomla\Database\DatabaseDriver->setQuery()</td>     <td>JROOT/administrator/components/com_kunena/src/Model/:68</td> </tr> <tr> <td>5</td>     <td>Kunena\Forum\Administrator\Model\CategoryModel->getAdminCategory()</td>     <td>JROOT/libraries/src/MVC/View/:146</td> </tr> <td>6</td>     <td>Joomla\CMS\MVC\View\AbstractView->get()</td>     <td>JROOT/administrator/components/com_kunena/src/View/Category/:122</td> </tr> <tr> <td>7</td>     <td>Kunena\Forum\Administrator\View\Category\HtmlView->display()</td>     <td>JROOT/libraries/src/MVC/Controller/:639</td> </tr> <tr> <td>8</td>     <td>Joomla\CMS\MVC\Controller\BaseController->display()</td>     <td>JROOT/administrator/components/com_kunena/src/Controller/:56</td> </tr> <tr> <td>9</td>     <td>Kunena\Forum\Administrator\Controller\DisplayController->display()</td>     <td>JROOT/libraries/src/MVC/Controller/:672</td> </tr> <tr> <td>10</td>     <td>Joomla\CMS\MVC\Controller\BaseController->execute()</td>     <td>JROOT/libraries/src/Dispatcher/:143</td> </tr> <tr> <td>11</td>     <td>Joomla\CMS\Dispatcher\ComponentDispatcher->dispatch()</td>     <td>JROOT/libraries/src/Component/:355</td> </tr> <tr> <td>12</td>     <td>Joomla\CMS\Component\ComponentHelper::renderComponent()</td>     <td>JROOT/libraries/src/Application/:143</td> </tr> <tr> <td>13</td>     <td>Joomla\CMS\Application\AdministratorApplication->dispatch()</td>     <td>JROOT/libraries/src/Application/:186</td> </tr> <tr> <td>14</td>     <td>Joomla\CMS\Application\AdministratorApplication->doExecute()</td>     <td>JROOT/libraries/src/Application/:294</td> </tr> <tr> <td>15</td>     <td>Joomla\CMS\Application\CMSApplication->execute()</td>     <td>JROOT/administrator/includes/:61</td> </tr> <tr> <td>16</td>     <td>require_once()</td>     <td>JROOT/administrator/:32</td> </tr> </table>
Last edit: 2 years 9 months ago by ProgAddicted.
2 years 9 months ago #227920 by rich
Please go to the database and check if the collation is actually utf8_general_ci, or just displayed incorrectly in your configuration report.
Joomla 4.x and also Kunena 6.0 the collation should be utf8mb4.
If this is not the case, you must change the collation to utf8mb4.
You can do this either with phpMyAdmin or with the Admin Tools from Akeeba. With Admin Tools you just have to select UTF-8 Multibyte under "Change Database Collation" (it is already preset) and run it. After that (as recommended) click on "Repair & Optimise Tables".
But first create a database backup.
2 years 9 months ago #227930 by ProgAddicted
Collation checked, it's the right one.
But I noticed this: trying to add a category it throws the error "1054 Unknown column 'parentid' in 'where clause'", but in the Categories table the column name is parent_id
2 years 9 months ago #227931 by rich
Correct is parentid. Please create first a database backup, then rename this column to parentid. Afterwards test your page again.
2 years 9 months ago #227934 by ProgAddicted
Done, much better now! Now I can see and use categories and discussions, but there is something else to adjust:
  1. the root category is not shown
  2. any attempt to modify any category, including the root one, ends in error: 0 3 arguments are required, 2 given
Time to create page: 0.319 seconds
