- Thank you received: 173
Kunena 6.4.8 Released
Solved "recent posts" does nog display all recent posts....
Which PHP version is the website running? take a look at menu system > System Information then tab php
and also the latest kunena version is 5.2.8
With kind regards
Leen
The website is not compatible with PHP version 8 (joomla or kunena isn't)
Kunena version is 5.2.7 and i do not see any updates available in the dashboard....
Sometimes one has to rebuild the Updates links for the latest Update to become available.
administrator > Extensions: Update Sites there put page number on everything and then check the top box and then click the rebuild button at the top
then go to Extensions: Update will empty first cache and then having it searched often he
With kind regards
Leen
but the results are still the same for the recent overview.
2. What is the menu item with the ID 170 for (see image) ? This menu item is wrong and should be deleted. You find this menu item in the Kunena menu.
Hi Rich,1. You have the configuration setting "Recent Topics Time Period = Month". Therefore, topics disappear automatically if there was no response for more than one month.
i know that it is set to a month, but now the messages are not displayed, even if the post is 1 minute old, but messages in several other topics that are the same age, ARE showed....
When i change the setting "hide" or "display" and don't change anything else on the filter, i see different posts in the recent list. You can see that in the pictures i posted earlier.
I don't know what that menu is for, as i stated before, i did not configure this forum, i took over from the previous guy who ran the forum.... so i really don't know.
I depublished that menu item, but i don't see any chages.
But i think i found something.
Normally i did the settings for the recent posts and such using the main overview in the front end tab.
But now i went to MENU and then to the settings of recent, there the settings were all wrong i think....
I changed the settings THERE to what i think should be OK, and i think it's OK now.....
i'll test and report back!
Thanks so far.
If you set "Use Global" in the menu item, then the setting from the configuration is displayed.
If you set "Show categories" or "Hide categories" in the menu item, then the setting from that menu item will be displayed (see picture).
All is working OK now :side:
