Kunena 6.4.9 & Kunena 7.0.1 Released
The Kunena team has announce the arrival of Kunena 6.4.9 [K 6.4.9] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
The Kunena team has announce the arrival of Kunena 7.0.1 [K 7.0.1] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Question installation failure
10 years 4 months ago #168879 by 810
Replied by 810 on topic installation failure
mhh,
try new site.
First install kunena. Check its working, then install cb.
The collation isn't the problem.
10 years 4 months ago #168894 by Lindener
Replied by Lindener on topic installation failure
OK.
Fresh Joomla 3.4.4 in MAMP/htdocs/Zaterdag
Fresh Kunena 4.0.5 installation via admin/extentions/upload package
the installation starts and stops after a few seconds.
Now there is a Kunena dashboard in admin/components, but redirecting to the errormessage.
Also the database shows the Kunena items.
I have not yet installed CB.
10 years 4 months ago #168895 by Lindener
Too bad!
Another try.
!. I quit MAMP and renamed my MAMP file to XXX_MAMP
2. Fresh MAMP 3.4
3. Fresh Joomla 3.4.4 in MAMP/htdocs/Kunena Proef
4. Fresh Kunena 4.0.5 installation via admin/extentions/upload package
5. Kunena was completely installed :)
6. Fresh CB 2.0.11 was completely installed.
It seems MAMP cannot handle 2 Joomla installations in one MAMP/htdocs.
Now I delete the second installation in my original Mamp. Rename etc.
further notice follows.
10 years 4 months ago #168897 by 810
if you have installed it on 2 different dir in htdocs. it should work. This is a strange behavior.
10 years 4 months ago #168898 by Lindener
Yess indeed.
After all this, now we are again at the beginning:
Table 'nieuw.bu2rk_kunena_configuration' doesn't exist SQL=SELECT * FROM bu2rk_kunena_configuration WHERE id=1
There is no kunena_configuration in the database.
The CBforum plugin is set to "0".
10 years 4 months ago #168899 by Lindener
Sure You have to clear the cache, afer all this. :sick:
Now I doubt: will I try to install Kunena now? I lost so many days.
Time to create page: 0.335 seconds
