- Thank you received: 1434
Kunena 6.2.6 released
Solved Quick Reply and Polish Characters
8 years 2 months ago #11
by 810
Replied by 810 on topic Quick Reply and Polish Characters
user is not activated or enabled, because i don't see the user on the latest user
8 years 2 months ago #12
by makitso
Joomla 4.4.2
Kunena 6.2.3
Replied by makitso on topic Quick Reply and Polish Characters
Well, I just logged into my site using test1 and make an update. It is noted on the front page. I don't know what is wrong.
Joomla 4.4.2
Kunena 6.2.3
8 years 2 months ago #13
by 810
try to change template, and try again, else there is a conflict with some plugin
8 years 2 months ago #14
by makitso
Joomla 4.4.2
Kunena 6.2.3
OK, will do some testing on my dev system.
Joomla 4.4.2
Kunena 6.2.3
8 years 2 months ago - 8 years 2 months ago #15
by makitso
Joomla 4.4.2
Kunena 6.2.3
We have learned that Polish characters start at ascii 260 and above and these are not displaying correctly. Characters under 260 display correctly.
Joomla 4.4.2
Kunena 6.2.3
Last edit: 8 years 2 months ago by makitso.
8 years 2 months ago #16
by makitso
Joomla 4.4.2
Kunena 6.2.3
OK, the problem has been discovered and fixed. Turns out that there was a bad function/trigger in the database. Once corrected it worked correctly.
Joomla 4.4.2
Kunena 6.2.3
Time to create page: 0.384 seconds
