- Thank you received: 2429
Kunena 6.2.6 released
Solved Kunena to import on a clean install
8 years 4 months ago #11
by rich
Replied by rich on topic Kunena to import on a clean install
I think I found your problem. The Joomla 3.x user tables have a other structure as from Joomla 2.5.
1. Go in your database and delete all Kunena tables and the Jomla user tables.
2. Import your backup tables again (all Kunena tables and the Joomla user tables)
3. Go in "Backend -> Extensions -> Manage -> (tab) Database" and click on Fix button.
4. Install Kunena
4. Install Kunena
8 years 4 months ago - 8 years 4 months ago #12
by Peppe-73
Replied by Peppe-73 on topic Kunena to import on a clean install
The problem is that the backup is uploaded to the DB, I tried today to just load the tables kunema eliminating tables from the user beckup. and gives me the same mistake I did not charge the beckup
allego file.sql
allego file.sql
Last edit: 8 years 4 months ago by rich. Reason: sql removed
8 years 4 months ago #13
by Peppe-73
Ok I did, the db was not completely empty there were 2 tables hidden
Thanks for all
Thanks for all
8 years 4 months ago #14
by rich
Your problem is solved now? I've removed your sql file, it should not be available for public.
Time to create page: 0.355 seconds
