Kunena 6.4.8 Released
Solved Forum Permissions
10 years 5 months ago #11 by applehc
Replied by applehc on topic Forum Permissions
Are you telling me prepare my old joomla 2.5 website again and update from it?
Kunena 4.1 obliges me to have Joomla 3.x
10 years 5 months ago #12 by 810
Replied by 810 on topic Forum Permissions
or J2.5.28
10 years 5 months ago #13 by applehc
Okay, I'll try.
10 years 5 months ago - 10 years 5 months ago #14 by applehc
810 wrote: or J2.5.28
Ahhhhhhhhhh
I installed Joomla 2.5.8 with Kunena Kunena 3.0.6. Then I replaced joomla users and kunena tables but permissions error continues :(
Last edit: 10 years 5 months ago by applehc.
10 years 5 months ago - 10 years 5 months ago #15 by rich
Replied by rich on topic Forum Permissions
If you import the Joomla 2.5 user tables to Joomla 3.4 it needs a fix. Go to "Extensions > Extension Manager > Database" and fix it. Maybe it helps.
Last edit: 10 years 5 months ago by rich.
10 years 5 months ago #16 by applehc
rich wrote: If you import the Joomla 2.5 user tables to Joomla 3.4 it needs a fix. Go to "Extensions > Extension Manager > Database" and fix it. Maybe it helps.
Appears this:
10 years 5 months ago #17 by rich
Appears this:
That's ok.
applehc wrote:
810 wrote: That's wrong.
First move the data then install k4.1.
so uninstall kunena, remove the kunena tables.
Then copy the all kunena table from the old database. Then install K4.0.1
Done. I copied all kunena tables of the old database and then I installed Kunena 4.1
And now? I see the default forum, all empty. I need to replace tables?
That irritates me somewhat. What do you mean with default forum? You see a clean new forum?
10 years 5 months ago #18 by applehc
rich wrote: That irritates me somewhat. What do you mean with default forum? You see a clean new forum?
Yes, I mean the forum clean. It looks same when recently installed.
When I install Kunena 4.1 version, eats the old kunena 3.4 tables and the forum looks clean without categories, topics...
It is a headache can“t migrate the forum correctly. I'm starting a worry .
10 years 5 months ago #19 by rich
1. Remove followings user tables in Joomla 3.4
*_usergroups
*_users
*_user_profiles
*_user_usergroup_map
2. Remove all Kunena tables in Joomla 3.4
3. Import the Joomla 2.5 user tables to Joomla 3.4
*_usergroups
*_users
*_user_profiles
4. Import the old Kunena tables to Joomla 3.4
5. Rename the prefixes (user and Kunena tables) to the same prefix as in Joomla 3.4
6. Go to Extensions > Extension Manager and fix the database
7. Install Kunena 4.0
that's all
10 years 5 months ago - 10 years 5 months ago #20 by applehc
rich wrote: 1. Remove followings user tables in Joomla 3.4
*_usergroups
*_users
*_user_profiles
*_usergroups
*_users
*_user_profiles
that's all
Hello rich,
I try it, but when I finish the process I access to the web links and appears:
No input file specified.
In the second step I have not delete kunena tables because do not exist. Only exist Joomla tables of the new install.
PD: Solved with .htcaccess i go to try again...
Time to create page: 0.228 seconds
