- Thank you received: 2
Solved Forum Permissions
When copying tables joomla and kunena in the database to use 4.0, generate changes in permits?
Users are part of "registered users" and categories are configured for it. When accessing a topic, I receive the next message:
Access Denied
EDIT:
I went to Kunena category mánager to change the categories permissions and when I saved changes for testing I receive this error:
Error
Unknown column 'icon' in 'field list' SQL=UPDATE `ubj25_kunena_categories` SET `parent_id`='7',`name`='Presentate',`alias`='6-Presentate',`icon`='',`icon_id`='0',`locked`='0',`accesstype`='joomla.group',`access`='1',`pub_access`='2',`pub_recurse`='1',`admin_access`='2',`admin_recurse`='1',`ordering`='1',`published`='1',`channels`='THIS',`checked_out`='127',`checked_out_time`='2015-06-21 12:10:50',`review`='0',`allow_anonymous`='0',`post_anonymous`='0',`hits`='0',`description`='¿Eres nuevo usuario? Presentate aquí.',`headerdesc`='',`class_sfx`='',`allow_polls`='0',`topic_ordering`='lastpost',`iconset`='default',`numTopics`='42',`numPosts`='236',`last_topic_id`='8814',`last_post_id`='11392',`last_post_time`='1377859630',`params`='{\"access_post\":[\"1\",\"6\"],\"access_reply\":[\"1\",\"6\"],\"display\":{\"index\":{\"parent\""3\",\"children\""3\"}}}' WHERE `id`='6'
Is this a new install? Or didn't you copy all the kunena tables?
810 wrote: you said you did a migrate before, I don't see any other versions?
It has not been an automatic migration.
I installed Joomla 3.4.1 with Kunena 4.1
Then I copy the joomla users tables and kunena all tables of the old database.
First move the data then install k4.1.
so uninstall kunena, remove the kunena tables.
Then copy the all kunena table from the old database. Then install K4.0.1
810 wrote: That's wrong.
Done. I copied all kunena tables of the old database and then I installed Kunena 4.1
And now? I see the default forum, all empty. I need to replace tables?
Then update kunena on the old website. Then copy the data to the new database
