Question Fatal installation problem
Joomla 3.1
Php 5.3.3
Mysql 5.5.33
I don't know what happened. HELP!!!
- 9themestore
- Premium Member
You try to login the your back-end and remove the Kunena forum component, after reinstall it.
The problem is that the install does not create any database tables. The folders and files are created but not the database.
I removed all Kunena related material and was able to restore the system but when I tried to install again I got the same error and system lockout.
I have installed Kunena 3.0 on another system with the same joomla, php, and mysql versions and it worked fine but it is not working on my primary system that I really need it for. I have also checked permissions and they are the same on both systems plus I have had no problem installing other extensions. Sorry for the long reply I just wanted to give you a full picture. Please help thanks
I am sure this problem can be fixed but it sounds like it might take a bit of work.
My first suspicion is that there's something wrong with your Joomla installation - which specific version of Joomla are you using ("J! 3.1" is vague).
The minimum technical requirements for K 3.0.3 are:
- PHP version 5.3.1 (you have PHP 5.3.3 - released in July 2010 - and PHP 5.4.14 or better is recommended); even though the minimum version is PHP 5.3.1 I cannot say if anyone else has reported problems with K 3.0.3 because they're relying on these very old versions of PHP.
- PHP max_execution_time: 30 or better.
- PHP max_upload_filesize: 3M or better.
- PHP GD_support: enabled.
- PHP DOM/XML: enabled.
- PHP JSON support: enabled.
When you wrote "I installed Kunena 3.03 through Install From URL on my site", I assume that you used the method described in K 3.0 Installation Guide (and watched the video). I assume that you have not altered any database permissions used by the MySQL account that's associated with your website. To be on the safe site, when I create my new Joomla sites, I use the SQL database manager (through cPanel) configured as shown in the following screenshot.
I assume that you are using a different database in this new site that you created to the database that you were using in your other site.
Here is more detail. In my second and third attempts I tried to install from this url:
joomlacode.org/gf/download/frsrelease/18...3.0.0_2013-05-15.zip
thinking that my system met those specs.
Joomla 3.1.5 (See screen shot for all details)
PHP 5.3.27
MySql 5.5.33
PHP Max File Upload = 16M
max_exetuion_time = 120
I looked in the install and saw the following had to be enabled so I double checked:
DOM, GD, JSON, pcre, SimpleXML are all enabled.
I use phpmyadmin to manage mysql and the user has ALL PRIVileges. Yes, they are 2 differnet databases but they have the same system configuration. Additionally, I have added AlphaUserPoints extension and it was able to create the appropriate tables.
"Table #__comprofiler_plugin_antispam_block successfully created
CREATE TABLE `#__comprofiler_plugin_antispam_block` ( `id` int(11) unsigned NOT NULL auto_increment, `type` varchar(255) NOT NULL DEFAULT '', `value` text NOT NULL, `date` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `duration` varchar(255) DEFAULT NULL, `reason` text, `params` text, PRIMARY KEY (`id`) )AUTO_INCREMENT=1, ENGINE=MyISAM
Table #__comprofiler_plugin_antispam_whitelist successfully created
CREATE TABLE `#__comprofiler_plugin_antispam_whitelist` ( `id` int(11) unsigned NOT NULL auto_increment, `type` varchar(255) NOT NULL DEFAULT '', `value` text NOT NULL, `date` datetime NOT NULL DEFAULT '0000-00-00 00:00:00', `reason` text, `params` text, PRIMARY KEY (`id`) )AUTO_INCREMENT=1, ENGINE=MyISAM"
I can't seem to submit a topic, is there an issue?
Do you mean that you were able to successfully install K 3.0.4 on a fresh installation of Joomla?onecrowd wrote: Hi, never resolved this issue but I did install on another server.
BTW, have I been banned or something because I no longer see the submit button?
