- Thank you received: 1
Merged Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation\n\t\t \n\t\t... OK\n\t\t \n\t\n\t\n"}
thank your for your support
unfortunately,this file doesnt exist
fixed with www.kunena.org/forum/k-3-0-installation-...lation-freeze#144173
- webmaisterpro
- Topic Author
xillibit wrote: Hello,
Try to look into \logs\kunena.php if you can see errors messages which can help.
File is missing from my "logs" folder
- Silentheal
I tryed to make in 3.0 with joomla updade but install not work.
Look my error.
Désolé, l'installation a échoué avec l'erreur suivante:
{"success":true,"status":"33%","current":"Pr\u00e9paration de l'installation","log":"\n\t\n\t\t
Pr\u00e9paration de l'installation<\/td>\n\t\t \n\t\t... OK<\/td>\n\t\t <\/td>\n\t<\/tr>\n\t<\/table>\n"}
{"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\tPrepare Installation<\/td>\n\t\t \n\t\t... OK<\/td>\n\t\t <\/td>\n\t<\/tr>\n\t<\/table>\n"
Argh, it broke almost immediately. First time Ive had a kunena fail in ages.
Any ideas?
Cant get the usual info output now to post.
latest joomla 2.5.11, php 5.3.10
Do you have third party plugins installed ? You need to disable themen and retry the Kunena isntallation.
Prepare Installation<\/td>\n\t\t \n\t\t... OK<\/td>\n\t\t <\/td>\n\t<\/tr>\n\t<\/table>\n"}
I am using Joomla 2.5.14. My site meets all current install requirements e.g. php etc.
Not sure what is going on here. I did see a previous post about uppercase database config but I checked the tables prefix and it is in lower case.
- tonyworship
- Junior Member
ERROR MESSAGE
Kunena Installation Failed!
