Merged Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation\n\t\t \n\t\t... OK\n\t\t \n\t\n\t\n"}
- webmaisterpro
- Topic Author
Well, I just tried to install latest Kunena 3.0 RC1, but installation freeze, showing the following message:
Here is my system information:
Database Version 5.1.68-cll
Database Collation utf8_general_ci
PHP Version 5.3.23
Web Server Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8e-fips-rhel5 DAV/2 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635
WebServer to PHP Interface cgi-fcgi
Joomla! Version Joomla! 2.5.11 Stable [ Ember ] 26-April-2013 14:00 GMT
Joomla! Platform Version Joomla Platform 11.4.0 Stable [ Brian Kernighan ] 03-Jan-2012 00:00 GMT
- webmaisterpro
- Topic Author
Matias wrote: You have probably displaying warnings, which for some reason break the AJAX reply (a bug?). Are you able to see (by using FireBug or similar tool) what the AJAX reply looks like?
I have already revert to Kunena 2, as the test was done in production website. Just a guess, that the issue might be related to CloufFlare CDN. I might try to reinstall it once more in a time with less traffic on my website.
Must be something else.
BTW: if installer fails, you could also try to visit the component as it tries to run installer again.
- webmaisterpro
- Topic Author
I also tried that, same error, actually not an error, just installation didn't go anywhere. I just checked other suggestion to try to install Beta first and after that RC, I will try this during the weekend and come back to report.
- webmaisterpro
- Topic Author
naimless wrote: Hi Webmaisterpro - I'm having the same issue with a similar configuration (but no cloudflare) - did you manage to resolve it by any chance?
Unfortunately not, yesterday I tried again with all connections and related plugins disabled, same error occur and I was not able to trace it. However I saw something strange into my server logs. Installation was looking for .asp files which is very odd!
Disable the plugin 'Azrul System Mambot For Joomla', go to Kunena administration and the install should proceed. Re-enable the plugin after that and all should be dandy.
Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation<\/td>\n\t\t \n\t\t.
your help will be so much appreciated
Ty in advance
Try to look into \logs\kunena.php if you can see errors messages which can help.
