- Thank you received: 1
Solved Installation error - Unable to create destination
- friday shoes
- Senior Member
I used the following telnet command
chown -R nobody:nobody /volume1/web/
I then tried installing kunena again using the same method at the beginning of this post and I get the same error.
docs.joomla.org/How_do_UNIX_file_permissions_work%3F
- friday shoes
- Senior Member
Although I am a little sceptical when people make the claim "I have the same problem" , for your sake I have merged the two topics together in the hope that, perhaps, you will both be able to help each other with this "same problem".Funesto wrote: Same problem I have in my thread ...
General information about folder/file ownership/permissions is given in the Wiki article Securing Kunena . The information in this article is obtained from Joomla.
Please understand, this is not specifically a Kunena problem. This is a problem relating to website administration.
docs.joomla.org/Security_Checklist/Hosting_and_Server_Setup
docs.joomla.org/Security_and_Performance..._hosting_provider.3F
These are things, what is NOT Kunena things, but Kunena is Securing too that and you cannot blame us! I think...
- friday shoes
- Senior Member
Could it be a problem with the Kunena installation files? What if I were to unpack the main zip and put all the folders within the package file into the correct libraries/components/media/plugin directories and go to discover instead in the extension installation menu?
I hardly ever see these folder/file permission problems these days because I never change these things when I first install Joomla.
But even though it takes next to no time to install Kunena, the process will not work the same way for you (as it does for everyone else) if the security on your site is different to a "standard" Joomla site.
For your information, I suggest you read carefully K 3.0 Installation Guide and watch the video.
- friday shoes
- Senior Member
Yes I did watch the video and read the guide, that's why I thought this would be a piece of cake, alas something so simple has turned into something quite complex.sozzled wrote: @friday: I have lost count of the number of times I have consistently, without failure, installed Kunena. On a standard, no-frills, uncomplicated, Joomla platform, it takes less than 30 seconds to install Kunena. I never unpack installation files; I rarely even download installation kits, these days, if I can avoid it. And, besides, the Kunena installation package is a bit "tricky" to run if you don't use Joomla to install the software for you.
