Kunena 6.2.6 released
Please Read This First:
Do not use this category for:
Question My cripsis template in Kunena 5.0.1 looks wrong
7 years 7 months ago #1 by stromboli
Hi!
I just installed 5.0.1 and the problem is taht the template looks like this:
prntscr.com/ccbpw4
Anyone knows how to solve it?
best regards,
Carla
7 years 7 months ago #2 by 810
On the crypsis settings - choose "Load Bootstrap" option, its on the basic settings tab
7 years 7 months ago - 7 years 7 months ago #3 by stromboli
Load bootstrap is selected
but the error continues
Last edit: 7 years 7 months ago by stromboli.
7 years 7 months ago #4 by robbrich
sorry to hijack this thread, but I am having the same issue with a new installation of joomla 3.6 and kunena 5.0.1. I searched the forums and saw that if I were to enable the bootstrap option in the template settings that it should work, but nothing I do changes the layout.
the site template is using 'JooSwatch' by joostrap.com
see attachment to see what is happening:
7 years 7 months ago #5 by robbrich
I did some digging and found the default bootstrap.css from the template was causing issues with this:
table td[class*="col-"], table th[class*="col-"] {
position: static;
float: none;
display: table-cell;
if I removed the 'float:none;' or changed it to 'float:left' then everything worked correctly.
7 years 7 months ago #6 by stromboli
I changed my Joomla bootstrap.css and no change. Did you mean Kunena's bootstrap file?
7 years 7 months ago #7 by 810
If col-md is the issue, then you need to enable crypsisb3 as default
col-md is a bootstrap 3 class.
7 years 7 months ago #8 by stromboli
Enabling crypsisb3 causes an error in my site:
0 - load error: failed to find /home/tresjolie/public_html/components/com_kunena/template/crypsisb3/assets/less/custom.less
7 years 6 months ago #9 by stromboli
Any other ideas of how to solve this problem?
I tried all the ideas of above but none worked
7 years 6 months ago #10 by 810
for your: 0 - load error: failed
backend - components- kunena - template -edit less
then the custom.less file will be created
Time to create page: 0.414 seconds
