configuration report
Merged Video: size problems and questions
9 years 7 months ago #21
by Kotsolis
Replied by Kotsolis on topic YouTube videos: Changing width-height
9 years 7 months ago #22
by xillibit
Replied by xillibit on topic YouTube videos: Changing width-height
Sorry i was in the wrong repository, the correct line is 1402
The following user(s) said Thank You: Kotsolis
9 years 7 months ago #23
by Kotsolis
I've changed all the video codes to be like this
'youtube' => array ('flash', 600, 360, 0, 0, ' www.youtube.com/v/%vcode%?fs=1&hd=0&rel=1&cc_load_policy=1 ', '\/watch\?v=([\w\-]*)' , array (array (6, 'wmode', 'transparent' ) ) ),
But no change at all.
9 years 5 months ago #24
by LudoMore
Replied by LudoMore on topic Video Width Not Changing
I found a solution to this problem. I was also wondering why my vimeo videos don't go over 400px in width no matter what i do...
There are 2 thing you need to tweak to make this work!
1. Go to
and edit file bbcode.php - change this line:
to
or any other preffered width/height you want.
2. If it is still not working then you need to go to the Kunena configuration page under Components / Kunena forum / Configuration / Frontend find Textarea Width and change width to width wider then your video. My videos are at least 640px so i put this to 720px and it is working.
Somehow text area width (while writing post) affects width output of the video.
1. Go to
/libraries/kunena/bbcode
'vimeo' => array ('flash', 400, 321, 0, 0, 'http://www.vimeo.com/moogaloop.swf?clip_id=%vcode%&server=www.vimeo.com&fullscreen=1&show_title=1&show_byline=1&show_portrait=0&color=', '\.com\/(\d*)', '' ),
to
'vimeo' => array ('flash', 640, 340, 0, 0, 'http://www.vimeo.com/moogaloop.swf?clip_id=%vcode%&server=www.vimeo.com&fullscreen=1&show_title=1&show_byline=1&show_portrait=0&color=', '\.com\/(\d*)', '' ),
The following user(s) said Thank You: aivos
8 years 8 months ago #25
by Kotsolis
Replied by Kotsolis on topic Video Width Not Changing
I already have text area width 700 and height 1300.
I changed number 1 as well by changing the line that you said for both vimeo and youtube. 640x340.
Still nothing.
Still nothing.
Time to create page: 0.377 seconds
