Kunena 6.4.8 Released
Sticky K 3.0 Kunena menu issues
12 years 4 months ago #148034 by Jiminimonka
Go to your Joomla Menu Manager and Publish the Kunena Menu.
Please read the FAQ.
Only one question per topic.
12 years 4 months ago #148059 by darthcricket
Publish didn't work, it must be something else. Here is the configuration:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : siteground-j16-20 | author: SiteGround | version: 1.0.0 | creationdate: Unknown
Kunena default template details : Example Template | author: Kunena Team | version: 1.7.2 | creationdate: 2012-01-31
Plugins: None
12 years 4 months ago #148073 by Jiminimonka
From your configuration report, I see you are talking about a localhost (XAMP or whatever) installation, which I am not too sure about support wise.
I also see you are not using the Kunena 3 template but rather an outdated one that does not work correctly with Kunena 3.
If publishing the Kunena menu in your Joomla admin does not work that is a Joomla issue, not Kunena, as Kunena relies and uses only the Joomla default menu system.
12 years 4 months ago #148086 by sozzled
Replied by sozzled on topic K 3.0 Kunena menu issues
Jiminimonka wrote: From your configuration report, I see you are talking about a localhost (XAMPP or whatever) installation, which I am not too sure about support-wise.
Here is the more "definitive" summary of the situation regarding support for local PC-hosted websites: Support for PC-hosted websites (e.g. WAMP, XAMPP) .
12 years 4 months ago #148382 by mikekiy
Replied by mikekiy on topic Menu does not appear
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 320M | Max file upload: 250M
Joomla default template details : cmia | author: Yes We Do Websites | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Third-party components: CommunityBuilder 1.9
Plugins: Search - Kunena Search 3.0.1 | Content - Kunena Discuss 3.0.1
Modules: Kunena Login 3.0.1
Hello
I have installed and set-up the Categories for my forum but I cannot seem to get the Kunena Menu to show.
In the template manager I have set the 'Display Kunena Menu' to yes.
However, the Menu will show if I click on the 'announcements' link.
I notice that the 'Kunena Menu' in the menu manager does not have a module associated with it. If this does need a module then what is the position that I should be using?
I look forward to hearing from you.
Kind regards
Mike
12 years 3 months ago #149202 by pcuser64
Hi installed Kunena in a zootemplate named zizia
I enabled in main menu like on this site.
and just like on this site (strange) when you click forum you go to the forum but
the forum menu buttom in not active this is a problem for me
should be active and highlighted
is there any way to fix this?
Time to create page: 0.392 seconds
