Merged K 3.0 Kunena menu issues
10 years 10 months ago #1 by mimimike64
Hello, I'm using joomla 2.5.11 and after an automatic update of kunena to version 3.0, my forum is no longer accessible and I get the following message. Thank you for the solution
10 years 10 months ago - 10 years 10 months ago #2 by sozzled
Replied by sozzled on topic K 3.0 Kunena menu issues
I suggest you read Kunena Menu issues in the Wiki. The principles that applied in K 2.0 apply here, too.
See also How To Ask Questions The Smart Way for a faster response.
Last edit: 10 years 10 months ago by sozzled.
The following user(s) said Thank You: kapil
10 years 10 months ago #3 by mimimike64
Replied by mimimike64 on topic K 3.0 Kunena menu issues
..ci dessous le rapport de configuration. Merci
below .. the configuration report. thank you
htaccess: Missing | PHP environment: Max execution time: 50000 seconds | Max execution memory: 90M | Max file upload: 40M
Joomla default template details : rt_lumiere | author: RocketTheme, LLC | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.0 | creationdate: 2013-05-15
Plugins: None
The following user(s) said Thank You: leito
10 years 10 months ago #4 by sozzled
It may be a good idea if you set your Kunena integration plugin settings in the way they are shown in Forum integration with other Joomla extensions .
It is also worth reading Search Engine Optimisation (SEO) in the Wiki.
The following user(s) said Thank You: azari59m
10 years 10 months ago #5 by mimimike64
Bonjour et merci mais j'ai tout essayé et rien ne fonctionne. Je vais reconstruire mon site afin de pouvoir installer le version 2.0.
Hello and thank you but I have tried everything and nothing works. I will rebuild my site in order to install version 2.0.
10 years 10 months ago #6 by Graça
Replied by Graça on topic K 3.0 Kunena menu issues
Hi
After update to 3.0 version, appears error 500 page not found. What is wrong?
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : shape5_vertex | author: Shape5.com | version: 2.0 | creationdate: Unknown
Kunena default template details : Orao - Kunena 2.x | author: www.TemplateKunena.com | version: 1.0.3 | creationdate: 15.12.2012
Plugins: Search - Kunena Search 3.0.0
10 years 10 months ago - 10 years 10 months ago #7 by sozzled
*** Topics merged ***
Please read Kunena Menu issues
10 years 10 months ago - 10 years 10 months ago #8 by Graça
Hello, Tankyou for reply
I rebulding the kunena menu, I used the trash menu, I switch off the SEO kunena and still the error 500 in page front. In administration joomla, menu manager kunena, when I try to clik in fix legacy button the error 500 occur in menu manager kunena.
Im lost...
Thankyou
Last edit: 10 years 10 months ago by Graça.
10 years 9 months ago #9 by Oscar2
Replied by Oscar2 on topic K 3.0 Kunena menu issues
I experience a similar problem, and after reading both the forum and the tutorial, still cant figure it out.
I get an error 500 after the update to Kunena 3. The menu is set up fine, I dont have other plugins inside the forum (I disabled uddeium to be sure) and Joomsef is not enabled for Kunena. I use the template Blue eagle 2.0 (version 3.0.0).
Strange thing; the forum doesnt work. The search page does work, but not when I actually search for anything.
Hope I can get some guidement here?
10 years 9 months ago #10 by Oscar2
The report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 50M
Joomla default template details : general_commerce | author: Shape5.com | version: 1.0 | creationdate: Unknown
Third-party components: UddeIM 3.0
Plugins: None
Modules: Kunena Latest 3.0.0
Time to create page: 0.640 seconds
