- Thank you received: 3
Kunena 6.4.7 Released
The Kunena team has announce the arrival of Kunena 6.4.7[K 6.4.7] in stable which is now available for download as a native Joomla extension for J! 5.0.x/5.1.x/5.2.x/5.3.x/5.4.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 6.4
Question After install site crashed
- cowboysdude
- Senior Member
810 wrote: Please enable kunena debug. And post here the error.
regards 810
Have no idea where that even is..
- cowboysdude
- Senior Member
Matias wrote: Can you also explain what exactly happened after the installation. Sometimes Joomla forgets to install some files or PHP uses the cached versions from them, so installing again may help.
It all installed fine... no problems on the backend at all.. works great.. except it crashes the site totally
- cowboysdude
- Senior Member
sozzled wrote: I'm sure Matias can respond better than me but I'm going to make a speculative suggestion.
1) Make a copy of your entire site and use the copy as a test platform.
2) Trash and delete your Kunena menu (see Kunena Menu issues
3) The upgrade procedure, itself, appears to work successfully. The errors occur after you have completed the K 2.0.x -> K 3.0.0 upgrade.
4) Upgrade the various Kunena Add-ons that you have installed
5) Try with v 3.0.0 of the Blue Eagle template
6) Retain your test site and post your configuration report for the test site so that we might be able to better see the whole situation clearer.
This approach keeps your existing site unchanged and allows you to continue to operate. Obviously, if the above approach (steps 1-5) work then you might consider doing the same on your live production site. I hope this helps.
Did everything you suggested and still the same results... just crashes my site on the frontend...
- cowboysdude
- Senior Member
There has to be an answer to this...
Uncaught exception 'RuntimeException' with message 'Library path __DIR__ cannot be found.'
- cowboysdude
- Senior Member
Changing PHP from 4 to 5.3 help
People cannot run Joomla if they are still using PHP 4.mikr23 wrote: I had a similar problem.
- Jiminimonka
- Elite Member
- YBAS!
regards 810
Login to your Joomla admin, then Kunena Configuration. In General there is an option for Kunena Debug Mode, set it to yes, and save the settings, then copy any errors that appear on your Kunena forum page (usually at the top of the page).
Also have you tried using the Blue Eagle Kunena template instead of the one you are currently using? I have seen you say you used a different Joomla template, please try to use the default Kunena one.
