Solved Kunena menu problems: menu disappeared after updating Joomla 3.3.6
- patchworker
- Topic Author
I updated my joomla from 2.5.28 to 3.3.6. Everything was finde including kunena, but in the backend my control-center was not available, so I replaced /libraries and /administrator/components/com_admin/sql/updates with the original files from the full package.
Now, my control-center is available, every other thing works fine, except for kunena There ist no kunena in frontend, neither in backend.
Frontend says: closed for maintenance
Backend says: Fatal error: Class 'KunenaForum' not found in .../administrator/components/com_kunena/install/model.php on line 1363
But I did not do anything in the com_kunena?! I only replaced /libraries and .../update in com_admin/...
Don't want to reinstall kunena and lose the settings and all the posts from the members.
Is this a known issue?
Anybody here can help me?
Thanks in advance!
patchworker.
- patchworker
- Topic Author
all.
Then install kunena again and the kunena language pack.
- patchworker
- Topic Author
In the former version in the frontend I had three tabs e.g. "current". Now they are gone.
Where can I acitvate them?
Thanks again for your fast help!
patchworker.
go to backend - menu - mainmenu - enable forum item.
- patchworker
- Topic Author
When you go to the kunena forum in frontend. Than there are the topics and above the possibility to login for members. And above that I formerly had three Tabs. Me and members could klick on "current" (or named similar - in german it was "Aktuelles") and there they could see only the newer entries.
If you go in backend to kunena -> configuration -> frontend you can declare that the current entries could be defined as "the last month" or "since last visit"...
But in frontend I cannot click this current view (sry for my english ).
Then the menu is german again.
- patchworker
- Topic Author
The tabs are missing. So you cannot look at the current entries.
But this is not the biggest problem. As I wanted to do your last tipp, I realised, that all the links are failing.
The categories in the mainpage from kunena are still there. In the right column the numbers of the posts are still correct. But when I click on a category, I get an 404 error "category not found"
The menu manager said: no mistakes. The click on restore menu was no help.
Sorry for the next problem
I have to leave now, but I will return tomorrow! Thank you very much for your help till now!
backend - kunena - tools - report
