Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Merged J 3.x: How to re-order/rearrange/sort Kunena categories in Category Manager?
12 years 9 months ago #144363 by ritesh_z
I'm testing Kunena 3.0 on a Joomla 3.1.1 test installation before going live. My question is about Reordering options in Kunana. This is the structure I've in Kunena:
1. - Laptops (section)
1.1 - Dell (category)
1.1.1 - Precision (sub-category)
1.1.2 - Inspiron (sub-category)
1.1.3 - XPS (sub-category)
1.2 - HP (category)
1.2.1 - Elitebook (sub-category)
1.2.2 - Probook (sub-category)
1.3 - Lenovo (category)
1.3.1 - Thinkpad (sub-category)
1.3.2 - Ideapad (sub-category)
2. - Tablets (section)
2.1...
These items were created in the order that is shown above. What I want to achieve is following:
1. Move "Inspiron" before "Precision".
2. Move "Lenovo" before "HP".
I've explored enough in backend but can't find an option to do it. Does anyone know how I can get this done?
Thank you.
12 years 9 months ago #144365 by ritesh_z
Okay, I've found how this is to be done. It was a little tricky though.
Apologies.
This thread can be deleted, if required.
12 years 7 months ago #146185 by Webbrent
Hi Everyone,
I have been searching for a while now, but haven't found a solution as yet pertaining to Kunena 3.0.1
I am using Joomla 3.1 with Kunena 3.0.1.
I have created numerous sections/categories in my forum layout, however would like to manually re-organize them. I know previously you could edit the order in which they appear in the front-end, but it doesn't seem as obvious a solution as previous.
Any assistance will be greatly appreciated.
12 years 7 months ago #146232 by sozzled
This is one of the cool features of Joomla's new Bootstrap templating system. The "trick" in J! 3.1 is to drag and drop the categories from one place to another. Yes, it's that easy! :woohoo:
The following screenshot shows you the widget you need to select with your mouse to perform the drag-and-drop action:
12 years 7 months ago #146363 by Webbrent
Fantastic! Thank you Sozzled. Took me a while and then noticed that I need to click on the Organize by this field before the Widget became selectable.
12 years 7 months ago #147033 by everstar
I am looking for a simple way to reorder the forums under a category. It looks like in older versions you could simply move them up in down in the categories manager where you add and delete them from the list. It apparently sorts by ID number. Is there a way to move them up and down so on the frontend they display how you want them. Example of Forums out of order because I was entering them in randomly and now I want them in the proper sequence.
Main
Forum 1
Forum 3
Forum 2
Main 2
Forum 2
Forum 3
Forum 1
Thanks!
Mark
Time to create page: 0.318 seconds
