Kunena 6.2.6 released
Solved Preview not working, a 404 Not Found error
9 years 1 month ago - 9 years 1 month ago #1 by bymamo
Hi!
I have a problem with error:
Forbidden
You don't have permission to access /index.php/foro on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
If I send again the hosting cut conexion with my ip.
I checked with other forum (external domain) and have same problem
Hereby attached problem text
Thanks for your help
Last edit: 9 years 1 month ago by bymamo. Reason: actualiced text
9 years 1 month ago #2 by 810
please add kunena report
9 years 1 month ago #3 by bymamo
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 750M | Max file upload: 32M
Joomla default template details : protostar | author: Kyle Ledbetter | version: 1.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.7 | creationdate: 2015-02-01
Kunena version detailed: Kunena 3.0.7 | 2015-02-01 [ Galah ]
Plugins: None
9 years 1 month ago - 9 years 1 month ago #4 by sozzled
I recommend that you change the forum integration plugin settings as shown in red below:
Kunena - UddeIM Disabled
Last edit: 9 years 1 month ago by sozzled.
9 years 1 month ago #5 by rich
Kunena - Gravatar Enabled: Disabled
Why should this be disabled? You don't know what is used on his page.
I've visited your page, but it works all correct. Is this problem only when you are logged in?
9 years 1 month ago - 9 years 1 month ago #6 by Mortti
Is there any change if you change your htaccess.txt file to .htaccess ( screencast.com/t/yNEsQOnZ46o5 ) and from Global Configuration of J! set "Use URL Rewriting" ( screencast.com/t/JEP0uepH ) ? Clean system and browser cache before and after testing.
Last edit: 9 years 1 month ago by Mortti.
9 years 1 month ago #7 by bymamo
Hi and thanks for all!
I checked your suggestions, only with preview option because if send topic, hosting banned my ip for 1 hour.
@sozzled, your changes didn't do anything.
@rich, you can use good non logged but if I am logged in (super user, registered and moderator) and put attached text have the problem.
@Mortti, I did that you said and it have same problem, now I am banned, I emailed hosting to inform.
Thanks for your support.
9 years 1 month ago #8 by bymamo
Now I have a lot of problems with invalid token.
I feel that I have to start from the beginning.
9 years 1 month ago #9 by sozzled
bymamo wrote: Now I have a lot of problems with invalid token.
If you would like honest professional assistance in setting up Kunena on your website—fast answers for all your questions—you know where to contact me. :)
The following user(s) said Thank You: bymamo
9 years 1 month ago #10 by bymamo
Well, I installed J! plus kunena...
We do categories and few topics...
I writte problematic text line by line and all go fine less text writing (no copy paste):
e p h e d r a ---- d i s t a c h y a
Could be that this plant would be banned automatic because is a non food plant?
Time to create page: 0.462 seconds
