This category is for discussing issues with the K 3.0 Blue Eagle template.
Question problem with dropdown button no showing
- Jiminimonka
- Elite Member
- YBAS!
10 years 8 months ago #11
by Jiminimonka
Replied by Jiminimonka on topic problem with dropdown button no showing
I will take a look at your site and see if I can spot whats up. If you contact Gantry support they might be able to come up with a solution as well, there may already be a solution posted there. Are you using the free Gantry template or one of Rocketthemes, because if its RT and you paid/subscribe the support will be faster than on the free version.
The following user(s) said Thank You: e654777
10 years 8 months ago #12
by e654777
Replied by e654777 on topic problem with dropdown button no showing
I am using the standard template already included with gantry download.
- Jiminimonka
- Elite Member
- YBAS!
10 years 8 months ago #13
by Jiminimonka
I don't know if this still holds true in the latest Gantry, but in the template manager, if there is an option Build Title Spans, disable that and see if it makes a difference. It used to cause lots of issues, but I think its gone from the newer versions (at least its gone from the new Rocket Theme templates).
10 years 8 months ago #14
by e654777
They took out build title spans. There is no more options to disable it.
- Jiminimonka
- Elite Member
- YBAS!
10 years 8 months ago #15
by Jiminimonka
Assuming you are not a member of Rockettheme, please post a support ticket at the Gantry support page -
www.gantry-framework.org/support
groups.google.com/group/gantry-framework...omla-users/subscribe
I will see if someone on the team here can offer a solution, but it might take a while.
10 years 8 months ago #16
by e654777
Yes, sir. I will do that. You have been very helpful. Thank you very much.
Time to create page: 0.585 seconds
