- Thank you received: 1
Question JomSocial and Kunena Karma Integration
www.kunena.org/forum/170-k-16-templates-...ation-from-jomsocial
yaksushi wrote: Neo I also responded to your post in the Jomsocial forums, maybe you can help me with the blow topic "pulling state and city from jomsocial into kunena"?
"Do or do not, there is no try..."
yaksushi wrote: Neo I also responded to your post in the Jomsocial forums, maybe you can help me with the below topic "pulling state and city from jomsocial into kunena"?
This was a very simple thing to do, I have updated my hack to version 2.2
Please note, if you already have version 2.1 installed you only need to upload files forumsettings.php and fsi2.php from version 2.2
Maker of:
JomSocial and Kunena Profile Integration
Both are available at my website.
/components/com_kunena/template/default/view/profile.vertical.php
/components/com_kunena/template/default/view/profile.horizontal.php
and change
to somehow query and display from my #__community_fields_values ?
All I need is the city state and country displayed under the avatar
One issue when you click on your jomsocial profile, there is no forum settings tab you must click on edit profile then it shows up in the sub menu. Might be confusing for users to get to. Can we add the forum settings into the dropdown menu?
Yes, this is simple, do the following:yaksushi wrote: Ok update, all the original things are working and the location is the house icon! Can I update it and replace Personal Text with the users city state country in text?
in forumsettings.php change
then in fsi2.php change
I have not yet gone looking to fix this because there is a way to do it with the plugin "Joomsocial Toolbar Editor" www.jomsocial.com/download/addons/conten...-toolbar-editor.htmlyaksushi wrote: One issue when you click on your jomsocial profile, there is no forum settings tab you must click on edit profile then it shows up in the sub menu. Might be confusing for users to get to. Can we add the forum settings into the dropdown menu?
I may look into making this part of my hack in the future, but first I need to finish looking into the requests I have received from people that have donated to my hack.
Maker of:
a. copying this file: /components/com_community/templates/default/toolbar.index.php
b. head to: /templates/{yourcurrentjoomlatemplate}/html/
c. create a new directory inside /html named: com_community
d. edit toolbar.index.php with your new menu info
e. paste toolbar.index.php inside the new com_community
to add a new menu to the toolbar.index.php do the following.
after the following code, line 164 for me in toolbar.index.php
past this after
Azure wrote: Well done, Neocold! Great solution!
As you're probably aware after your direct intervention with bedding your other excellent hack in for me, I have changed the Kunena Karma to an 'applaud' system, completely disabling negative karma so that only positive feedback can be given to a poster. I am using Jomsocial to display member profiles but because of the craziness of operating two different karma systems, switched the JS one off.
Could your hack be tweaked to display my 'applaud' (positive karma) count on the JS profile page without having to set up the JS karma system? Further, would it be feasible to be able to include Kunena 'thank you's' received and given on the Jomsocial profile page?
Cheers,
Azure
Azure, your request has been completed and applied to your website, if you have any questions or requests about it feel free to PM or email me.
Maker of:
However (and this is a personal preference), I believe that the link to my Forum Settings page is more appropriately placed under the Profile dropdown. This method is also much simpler to apply manually.
Edit file **/components/com_community/libraries/toolbar.php
change:
to:
yes, essentially you are just adding another part, but I find it more clear to tell people to change than to add
yaksushi, sorry I couldn't do this for you immediately, but as I'm sure you understand I must meet supporters requests first
This is now available in version 2.3 of my JomSocial and Kunena Profile Integration
Maker of:
I'll be putting something under your Christmas tree for tomorrow morning. Promise not to look and make sure you leave me a bottle of Guinness on the mantle. I have a bottle opener.
Cheers,
Azure
