Question [Merged topic]K 1.7.1 and Jomsocial Activity Stream
12 years 2 months ago #71 by sozzled
The last time that PIC posted a Kunena configuration report, the report had been severely edited.
We only know, from that report, that PIC was using an unsupported, outdated (and probably broken) Kunena template that had been designed for an earlier version of Kunena. We also only know, from that report, that PIC was using K 1.7.0, Kunena Latest 1.7.0, Kunena Search 1.6.4 and Jomsocial 2.2.4. We do not know anything more about PIC's website (e.g. what version of Joomla is installed, webserver software, MySQL, PHP, anything else that may help us to help this person). If people do not want to share certain information with us, that's OK, but they should also expect that it may take a very, very long time to guess what might be the cause of the problem.
So, while we are totally in the dark as far as what is happening in PIC's particular circumstances, we're pretty much in the dark as to how to go about solving PIC's particular problems.
12 years 2 months ago - 12 years 2 months ago #72 by PIC
sozzled wrote: The last time that PIC posted a Kunena configuration report, the report had been severely edited.
Kunena activites do not show up in my activity stream after upgrade. That is the only symptom I have.
Here's a report. I'm currently using Joomla 1.7.1 and Kunena 1.7.3 and Jomsocial 2.4.2.
I see Joomla now has a 2.0 upgrade. It looks like they want you to download 2.5 instead of 1.7, but I think it's RC1.
Debug mode is on, but I'm not seeing any messages.
I doubt the kunena template being outdated would have anything to do with the activities not showing up in JS activities.
I'd greatly appreciate any help I could get.
htaccess: Exists | PHP environment: Max execution time: 200 seconds | Max execution memory: 200M | Max file upload: 200M
Joomla default template details : yoo_quantum | author: YOOtheme | version: 1.0.7 | creationdate: August 2011
Kunena default template details : ArgentRC Dark | author: Gonzaunit | version: 1.6.0 | creationdate: 2010-08-20
Third-party components: Jomsocial 2.4.2
Plugins: System - Mootools Upgrade: Disabled | System - Mootools12: Disabled | Kunena Search 1.7.1
Modules: Kunena Latest 1.7.1 | Kunena Stats 1.7.1 | Kunena Login 1.7.1 | Kunena Search 1.7.1
Last edit: 12 years 2 months ago by PIC.
12 years 2 months ago #73 by PIC
I fixed it... I'll explain here in a bit.
12 years 2 months ago #74 by sozzled
Thank you for your updated configuration report. Your Kunena template - ArgentRC Dark - is outdated and, more importantly, is not supported by the Kunena project team. If you have problems with Kunena when you are using that template, please contact the author of that template. Good luck in continuing to use outdated and unsupported software.
12 years 2 months ago #75 by PIC
As I said, I wouldn't expect Kunena to help me with template problems.
This issue is unrelated to the template and is related to user permissions. You must set all the Kunena categories to "user groups" instead of "access level". Kind of strange because before the upgrade it wouldn't work on "access level, so it was set to "user groups". So I guess the update has switched which permissions setting doesn't work.
Yeah, I don't enjoy using an outdated template... if only a supported template would fit the look of my page!
12 years 2 months ago #76 by erkan
The solution for me was to downgrade to Kunena 1.7.0 and then wait for Kunena 2.0 which as I understand has improvments in the ACL function.
12 years 2 months ago #77 by erkan
So now fix for this problem in Kunena 1.7.2 either :angry:
And now you are forsing my to update from a working Kunena 1.7.0 to 1.7.2 because of Joomla 2.5 support.
12 years 2 months ago #78 by sozzled
erkan wrote: And now you are forcing my to update from a working Kunena 1.7.0 to 1.7.2 because of Joomla 2.5 support.
No. That is not true. J! 2.5.0 contained some serious problems that affected hundreds (thousands?) of Joomla extensions. J! 2.5.1 has been released to fix those problems.
The problems that are being discussed in this topic affect the JomSocial Activity Stream. I don't know anything about JomSocial (or the JomSocial Activity Stream). Sorry, I can't help with those things.
12 years 2 months ago #79 by erkan
So I can still run Kunena 1.7.0 (which works good with Jomsocial) if I have Joomla 2.5.1?
12 years 1 month ago #80 by triscoe
PIC wrote: As I said, I wouldn't expect Kunena to help me with template problems.
Thank you for this, been pulling my hair out to find a solution and here it is. Maybe this should be published somewhere or pinned as a known solution if the activity stream is not showing up in J!2.5 and K.1.7 and Jomsocial 2.4?
Time to create page: 0.444 seconds
