- Thank you received: 566
Kunena 6.4.8 Released
Important Kunena 1.5 to 1.6 Language Conversion Tool
- rinuccio sp
- Premium Member
- Thank you received: 4
xillibit wrote:
Please, add a comment indicating the presence of new entries for each version.rinuccio sp wrote: 3°)The script just convert things, so you need to add manually the news strings added in K1.6
Or, continue to put in a column new entries.
For some extensions, you must navigate the whole file before you identify the part to translate.
ES:
//Kunena 1.6.3
xxx
xxx
xxx
//Kunena 1.6.4
This is Italian language (only front end) complete :woohoo:
However we can easily create a list of changes from version to version based on the svn. We should supply that list once we have a baseline for each language. It will make it very easy to spot new or changed language strings.
en-GB.com_kunena.ini
This is bug or what?
The languages files are in administrator\language\en-GB and \language\en-GB, execept one little language file for the template, which is located in components/com_kunena/template/default/language/en-GBRandal wrote: Why main language is in Kunena language folder and not in "administrator\language\en-GB" and "language\en-GB"?
