Question Problem in IE8
Can be corrected by adding size=700 to te code but this has to be done manually.
URL: www.hobbykwekers.nl/component/option,com.../func,view/id,67/#85
My websites: AquaInfo.org | AquaInfo.nl
- grumblemarc
- Elite Member
- Still making trouble
- Thank you received: 3
"Spot a bug? please let us know here!"
- grumblemarc
- Elite Member
Do not post bugs or support questions in the testing forum. Since it is for users to test out certain aspects of Kunena in a live environment posts here are pretty much ignored.
This is strange, i am surprised about that. Here in the testing forum is a sticky thread, called: Kunena 1.0.8 Report bugs and Typos here! and as John wrote,is its description to post bugs here and if you look in this thread 98 per cent (circa) of all users are posting bugs here.
Now i am a little bit confused. I'ld suggest, the moderators should move all posted bug-threads into the right forum (support) and change the discription of the testing forum. It is not the fault of the users
If an external image is added, IE8 shows the picture correctly 700 pics wide (maximum on my forum), however the forum gets wider to fit the original picture before downsizing. IE7 shows just fine.
Test the lightbox-plugin, perhaps, this fixes this problem.
www.kunena.com/forum?func=view&catid=20&id=7531
A question to IE 8: there is no standalone installation near IE7 possible, or?
IE8 replaces IE7, cant have them both at the same time.
Adding: JHTML::_('behavior.mootools'); to the index.php in my template directory doesnt help. (in IE8 got to check 7).
In IE7 it just looks fine. When moving mouse over an image it shows a hand. When clicking it, the windows shows only the photo in full resolution. The same in IE8.
