- Thank you received: 176
Kunena 7.0.7 Released
Use this category:
Use this category:
Solved Forum lost categories after upgrade to J4
2 years 10 months ago #229035
by Leen
With kind regards
Leen
Replied by Leen on topic Forum lost categories after upgrade to J4
I followed your explanation.
With the exception that after kunena version 6 I was uninstalled.
I first imported the old kunena V5 data .sql.
And I also saw in Maintenance: Global Check-in that category table of kunena had to be checked in there.
but further your adjustments in categories and ranks
done and yes I must say then it does indeed work.
But then it is also to be hoped that one will also be there somewhere
the old kunena v5 media files is called saved so
one can still use it.
With kind regards
Leen
- Thank you received: 2536
2 years 10 months ago - 2 years 10 months ago #229049
by rich
Replied by rich on topic Forum lost categories after upgrade to J4
Can we please try to solve the problems one by one? It is simply too exhausting when various errors are to be fixed in a single topic.
The fact that you can't open themes is probably because no categories are published. I've noticed that categories that are not published still show as published in the backend. Publish some categories and then try to create a topic.
By the way: The database collation for Joomla 4.x and Kunena 6.x should be utf8mb4_unicode_ci or utf8mb4_general_ci.
Last edit: 2 years 10 months ago by rich.
2 years 10 months ago #229069
by aleffting
Replied by aleffting on topic Forum lost categories after upgrade to J4
Hi Rich
Thank you. I am unable to create any categories to publish on the back end. No pre-existing categories made it through the update, and the back end gives the error each time I try on the back end. I added my observations of what was happening on the front-end to give some perspective that would perhaps give further insight.
I'm sure that the primary cause behind all of is that the categories did not survive the upgrade, despite doing our best to uninstall on the J3 site and install as per the documentation.
Thanks for noting the correct database collation - is there a script one can run via phpmyadmin to update this perhaps? Or would it just be better to uninstall K6.1.x and try to install it afresh again, or is it likely to lose the entire history in that scenario?
Many thanks.
Many thanks.
2 years 10 months ago #229072
by Gindi
Replied by Gindi on topic Forum lost categories after upgrade to J4
In phpmyadmin this is quite simple.
You can set the collation by clicking on "Operations" at the top and then scrolling all the way down. At Collation click the pulldown menu and scroll all the way down and select unicode_ci or general_ci under utf8mb4.
Below that click "Change all table collations" and if you want also "Change all column collations". Then click on OK in the lower right corner.
Then wait until the message appears that the character set has been changed. With large databases this can take a moment.
Important: Make sure to create a backup first.
Gindi
Gindi
The following user(s) said Thank You: aleffting
2 years 10 months ago #229082
by aleffting
Thanks very much, Gindi, will give that a go.
Alison
Alison
2 years 10 months ago #229085
by Gindi
Once your collation is corrected, you can migrate the Kunena data from Joomla3 to Joomla4 following the instructions below.
Migrate the forum and users to a new site
Gindi
Gindi
Time to create page: 0.263 seconds
