Kunena 6.1.1 Released
The Kunena team has announce the arrival of Kunena 6.1.1 [K 6.1.1] which is now available for download as a native Joomla extension for J! 4.2.x/4.3.x. This version addresses most of the issues that were discovered in K 6.1.0 and issues discovered during the last development stages of K 6.1
Use this category:
Question JInstaller: :Install: SQL-Fehler Duplicate entry 'com_kunena.reply-' for key 'PR
7 months 4 weeks ago #11 by martinsai
Hi Rich, I checked the old website (Joomla 3 before migration) and even there I could not find the mentioned table. Maybe I was searching wrongly. Can u tell me where or how to find this mail table?
7 months 4 weeks ago #12 by Leen
Martin,
the xxxxx_ mail_templates only occurs in joomla 4
L.v.d.A
7 months 4 weeks ago #13 by martinsai
ok, first answer is see attachd image: in extension manger kunena is displayed but not on dashboard >components!!!
7 months 4 weeks ago - 7 months 4 weeks ago #14 by Leen
I miss System - Kunena Forum can it be found at joomla4 plugin manager ?
and is the database okay does Maintenance: Database give no error message?
L.v.d.A
Last edit: 7 months 4 weeks ago by Leen.
7 months 4 weeks ago #15 by rich
(By the way everything else works except Kunena)
If the #__mail_templates table is not present, no mails will be sent.
Install Joomla again via Joomla Update. Maybe you are lucky and this table will be created.
7 months 3 weeks ago #16 by martinsai
Hi Rich, now all missing data tables (including mail_templates) have been inserted but still cant install kunena. I am going mad. Even deinstalling did not work: see img
7 months 3 weeks ago #17 by Leen
in Extensions: Manage
click green V to turn extension off
and select the extensions again with square and click on
uninstall then you should be able to get those 2 away
L.v.d.A
7 months 3 days ago #18 by HarryT3
Hi
If you have still this issue, the problem is 3 entries in the table jos_mail_template  (assuming you have the default jos_ prefix)
After a complete uninstall you can, as a workaround, open your database with phpmyadmin and enter the sql statement
delete FROM jos_mail_templates where template_id like 'com_kunena%'
Afterwards you can install Kunena again.
{HT}
Time to create page: 0.331 seconds
