Kunena 6.2.6 released
Do not use this category for:
- asking questions about how to make simple changes to a template designed by the Kunena project team (use K 3.0 Templates instead);
- advertising your own template designs.
Question Unable to load Bootstrap after upgrade
- Toutankhamon
- Topic Author
- Junior Member
I've upgraded my "old" Kunena to the latest version (Ganymede, because I The Expanse too).
Bad decision because I can't load Boostratp in the template parameters of Crypsisb3 (the option is not available).
More weird, the Bootstrap option is available for Crypsis template but the frontend display isn't as expected.
I've checked the databse (no issue) and the diagnostic in the forum options (no issue).
I past below my report configuration so you can have a look.
Thanks in advance
Part of the message is hidden for the guests. Please log in or register to see it.
This option is only available for Crypsis and loads the bootstrap 2 css, so you can use Crypsis also for older Joomla templates which still no have Bootstrap.Bad decision because I can't load Boostratp in the template parameters of Crypsisb3 (the option is not available).
Crypsis b3 don't need this option, it use the bootstrap 3 css from your Joomla template.
Have you a link to this Forum?More weird, the Bootstrap option is available for Crypsis template but the frontend display isn't as expected.
- Toutankhamon
- Topic Author
- Junior Member
- Toutankhamon
- Topic Author
- Junior Member
No solution provided for the display issues after the upgrade?
Another issue: sounds like the categories are hidden by default, no matter the template used. I have to to click the button (see screenshot attached) at the right of the section name to display the child categories. By default, the categories must be displayed, right?
Thanks in advance for your support.
- Toutankhamon
- Topic Author
- Junior Member
