Kunena 5.1.3 Released (19 Aug 2018)
The Kunena team has announce the arrival of Kunena 5.1.3 [K 5.1.3] which is now available for download as a native Joomla extension for J! 3.8.x. This version addresses most of the issues that were discovered in K 5.1 and issues discovered during the development stages of K 5.1. This is a maintenance release.
× This section is for questions directly related to the procedure for installing Kunena for the first time or upgrading from an older version of Kunena.
Use this category:
Question Error after upgrading Kunena
1 week 3 days ago #1 by Zoetermeer Actief
I have Kunena 5.0.14 on my site and it always worked fine. But when I update to a higher version of Kunena, it doesn't display my posts any more. On the forum, I can see the different categories, but when I click on one of the subjects, it disappears and I see only the members and statistics.
Do you know what causes this problem?
Regards, Rita Soutendijk
1 week 3 days ago #2 by Pinkeltje
Do you use a third party template?
1 week 3 days ago #3 by Zoetermeer Actief
Yes, I have a rocket theme template. I already tried to change the template to default joomla protostar for the Kunena forum, but this did not work.
But with the rocket theme template and version 5.0.14 it still works.
1 week 2 days ago #4 by Pinkeltje
I meant Kunena template, not Joomla template.
1 week 2 days ago #5 by Zoetermeer Actief
I guess not, I actually did not know it existed!
1 week 49 minutes ago #6 by 810
Replied by 810 on topic Error after upgrading Kunena
Could you post the kunena report.
Backend - kunena - tools- report
6 days 17 hours ago #7 by Zoetermeer Actief
Thanks for the tip! I found the report, this is from my life site (with older version of kunena):
htaccess: Exists | PHP environment: Max execution time: 60 seconds | Max execution memory: 256M | Max file upload: 64M
Warning: Spoiler! [ Click to expand ]
Joomla default template details : rt_notio | author: RocketTheme, LLC | version: 1.1.1 | creationdate: November 2, 2017
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.0.14 | creationdate: 2018-03-14
Kunena template params:
Kunena version detailed: Kunena 5.0.14 | 2018-03-14 [ Stephen Hawking ]
Plugins: None
And this is from my test site, with kunena upgraded and not working:
Kunena default template details : Crypsis | author: Kunena Team | version: 5.1.3 | creationdate: 2018-08-19
Kunena version detailed: Kunena 5.1.3 | 2018-08-19 [ Dione ]
Plugins: None
6 days 10 hours ago #8 by rich
Replied by rich on topic Error after upgrading Kunena
It lacks your Kunena menu. Kunena requires an undestroyed Kunena menu.. If it does not correctly exist, then these errors occur. Repair your Kunena menu items, then it should all work.
Please see also here
  • Not Allowed: to reply.
  • Not Allowed: to add attachements.
Time to create page: 0.145 seconds
