Kunena 6.2.6 released
Use this category:
Question Kunena duplicates posts
- romagromov
- Topic Author
- Senior Member
When user replies in topic, Kunena duplicates posts 4-5-7 times.
It happens not always, but each day I should to delete extra duplicate posts.
Download Free Software for Windows absolutly free.
- romagromov
- Topic Author
- Senior Member
rich wrote: I think, it's at a single user where occours this problem. Is this right? Please see this topic: www.kunena.org/forum/k-4-0-support-archi...st-publication-error
No, it happens with different users.
User writing post and press send button. Then Kunena 10-20 seconds trying to send post, and finally duplicates post several times.
But it happens not always, but every day.
May be it happens with specific topics, but I'm not sure.
Are this users moderators?User writing post and press send button
Maybe therefore the user clicking again?Then Kunena 10-20 seconds trying to send post
You can test it. Write a post as moderator and double click on send button. The result are two messages.
If you try the same as a registered user, you get the message "Duplicate message ignored (or similar).
- romagromov
- Topic Author
- Senior Member
No, those users - not moderators. Usual users.
Did you test it yourself? Test it also with flood protection (configuration -> tab security). Set the flood protection to value 10. If you still can send as normal user (with double click) 2 messages, then check the user rights.rich wrote: You can test it. Write a post as moderator and double click on send button. The result are two messages.
- romagromov
- Topic Author
- Senior Member
Is it possible to send email notifications using cron jobs?
- romagromov
- Topic Author
- Senior Member
- romagromov
- Topic Author
- Senior Member
It's not possible actually, maybe we can add that in a future versionromagromov wrote: I believe, that issue is with email notifications.
Kunena save the message in database and then try to send the subscription mail, so it's two things which works separatly, i will make some test to see what is considered like spam in the subscription mail.
P.S.: can-you put please in confidential tag the settings of smtp part into Joomla! ? Your message has been rejected, because your are blacklisted : support.symantec.com/en_US/article.TECH169847.html
