Kunena 5.2.8 released and Blue eagle 1.6.7 released (02 Jan 2022)
The Kunena team has announce the arrival of Kunena 5.2.8 [K 5.2.8] which is now available for download as a native Joomla extension for J! 3.10/3.9.x. This version addresses most of the issues that were discovered in K 5.2 and issues discovered during the development stages of previous version of K5.2.
If you are using blue template you need to update to 1.6.7 version to ensure to have a compatible version with K5.2.8.
Important note: (07 Jan 2022) If you have created a Kunena custom.css, create a backup of it. Due to an error, this file will be deleted during an upgrade.
× This section is for questions directly related to the procedure for installing Kunena for the first time or upgrading from an older version of Kunena.
Use this category:
Solved Kunena upgrade from 1.7 to 5.x with step 3.0.7 breaks
5 years 1 month ago #11 by Smoker_Creep
Sorry don't now which admin tool you mean didn't found in Kunena? ... before I'll do it by hand for each table ... thanks!!!
You think this should also fix the "base" statistics issue?
best regards!
5 years 1 month ago #12 by rich
Admin-Tools is a extension from Akeeba.
5 years 1 month ago #13 by Smoker_Creep
oh thanks never used, saved a lot of time!!!
... so with database collation rewrite installation seems to run proper! Seems we fixed the update problems!
and for the general statistics I'm so sorry it was unset in the Kunena configuration
(maybe didn't thought of it, because it was displayed on site with all zero values)
MANY MANY THANKS FOR THIS FREE SERVICE AND HELP!!! Also to all Kunena developer!!!
will let the huge community and operator of the forum donate for it if goes online next year!
All bests!
  • Not Allowed: to reply.
