Kunena 6.3.5 released
The Kunena team has announce the arrival of Kunena 6.3.5 [K 6.3.5] in stable which is now available for download as a native Joomla extension for J! 4.4.x/5.0.x/5.1.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 and issues discovered during the last development stages of K 6.3
Note: Please go to the Kunena Dashboard after an upgrade so that the Kunena database tables are also updated.
Use this category:
Question Template problem for Kunena 5.0.2
7 years 11 months ago - 7 years 11 months ago #11 by hanssie
I have the same problem. I just have updated kunena from 4.12 to kunena 5.0.2, during the installation everything was alright but when I went to see the result was absolutely awful!!
- No Menus..... (only text and no layout).
- I use joomla 3.6.3 and my joomla template has a white background. It seems that the new template doesn't looks nice if you are using a white background.
- the avatars are too big! (I've resized them manually).
Please make it possible to use the old template (or introduce a simular look and feel) within the new kunena version, or give me a procedure how to upgrade the layout of my forum.
Last edit: 7 years 11 months ago by hanssie.
7 years 11 months ago #12 by lagad
hello,
thanks for the work of this new template.
is it possible to have your configuration forum of this site as we can copy it ?
i have lots of screens problems and I wanted to be sure that i'm starting well with the basic configuration.
thanks in advance
7 years 11 months ago #13 by 810
Please enable "Load Bootstrap" option on the crypsis settings.
7 years 11 months ago - 7 years 10 months ago #14 by lagad
already done (i read the entire post).
here my problems :
box for connexion doesn't match very well with pictures :
and it is not possible to deconnect. --> Ok corrected with the last version !
with phone, it doesn't work very well : i need to select few time befor the box open.
I prefer to have each button for each action. --> Ok, corrected by kunena \ crypsis template \ parameter \ Show default actions = No
The choise doesn't work very well when i click on it, and with a phone, it doesn't work very well.
The text place is not long enough when i click on "answer".
i always need to readjust the box befor writing in it.
The button picture, video, and all the other doesn't work at all.
And I also have problem to size the picture and make them to have good look.
I don't really understand for what is for all the parameter of the avatar in the parameters of the template.
does it possible also to always have the "more information" open ?
--> Ok : on the crypsis options, clear the option at basic tab - Default category icon
I also noticed that on phone, when you read the "last message", it's only possible to go to the last message by choosing "new message".
But if you already read it, you cannot choose "last message", the link doesn't work at all.
I need to select the title of the message, then choose the last page and then go down of the page to see the last answer.
Thanks a lot for your answers.
Last edit: 7 years 10 months ago by lagad.
7 years 10 months ago - 7 years 10 months ago #15 by lagad
nobody to answer me ?
is my question too bad ?
I also have the same problem as written here : www.kunena.org/forum/k5-0-support/138986...-on-the-topic#181064
7 years 10 months ago #16 by 810
if you set a question, you need give us a link, and demo account, so we can check it. If you do only images, then we can't do anything, The issues are css conflict with your joomla template.
The following user(s) said Thank You: lagad
7 years 10 months ago - 7 years 10 months ago #17 by lagad
Hy,
thanks for your answer.
template used : www.template-joomspirit.com/joomla-free-.../category_pathway-12
website : www.aslpaintball.com
waiting for your return ;)
edit : do you need an administrator acces ?
7 years 10 months ago #18 by 810
.markItUpEditor { min-height: 250px; } .markItUpHeader ul a { padding: 14px; }
add this on the custom.less
backend - kunena = template - edit less - custom.less
and change option icon type: this will fix the double icons. and the category icons
backend - kunena - template - crypsis - features - Topic Icons set to font awesome
7 years 10 months ago - 7 years 10 months ago #19 by lagad
done,
but still have some problems
(i cleared the cache)
7 years 10 months ago #20 by 810
.content { display: inline-block !important;} .profile-expand .heading { display: none !important;}
for the open more
Time to create page: 0.445 seconds
