Kunena 6.2.6 released
Use this category:
Question Template problem for Kunena 5.0.2
- Jacques_1257
- Topic Author
I just have updated kunena from 3.something to kunena 5.0.2, during the installation everything was alright but when I went to see the result was absolutely awful!!
It is probably a problem with the joomla template? or the joomla version (3.6.2)? or with a plugin?
This forum is our working tool and we really need it
How can I recover the older version? Help!
Thx in advance.
backend - kunena - template - crypsis - basic settings tab - "Load bootstrap" set to yes.
- BilboHouse
I´m having a little problem with "Crypsis" template on a website, the icons like "login icon", "password, "more" and much more don´t show at the forum. I test it with firebug and changing or adding "s" at the class of the item appears. (this problem appears after upgrade)
ORIGINAL
Yo can show it at the attachments.
Best regards
backend - kunena - template -edit less - custom.less
- BilboHouse
Thanks for your fast reply, I tried it and the solution don´t solved the problem. I erase the cache of the joomla yet with the same result.
- Jacques_1257
- Topic Author
Thank you for the reply, yes I think that this is a joomla template compatibility problem
Just as BilboHouse, putting "Load Bootstrap css" to YES didn't help…
I will try now to edit the custom.less file …
thx
- Jacques_1257
- Topic Author
If I put this
[class^='icon-']::before, [class*=' icon-']::before {
font-family: FontAwesome;
on the custom.less file I obtain the following:
0 load error: failed to find /home/amaru610/public_html/components/com_kunena/template/crypsisb3/assets/less/custom.less
until then add the code on the
custom.less file from crypsis not on crypsisb3
I have a similar problem with the Forum since updating to newest version. Before everything looks good.
But after update the structure ist destroyed. See the number ob pages (other postings with more responses show there
between numer 1 and "weiter all other numbers of pages.
How I can fix it? Is there the possibility to downgrade to Version 4.x ?
How I can place the User-Icon and Name on the left side, similar to this Forum here?
BR
Michael
With update from Joomla 3.6.2 to 3.6.3 it works fine!!!!
