Question
Habe ein Problem mit mod_kunenalatest_1.0.47 beim installieren
Hallo,
wenn ich mod_kunenalatest_1.0.47 installiere, kommt auf der homepage startseite diese Meldung:
Warning: include_once(C:\xampp\htdocs\xxx\components\com_kunena\lib\kunena.debug.php) [function.include-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\xxx\modules\mod_kunenalatest\helper.php on line 9
Warning: include_once() [function.include]: Failed opening 'C:\xampp\htdocs\xxx\components\com_kunena\lib\kunena.debug.php' for inclusion (include_path='.;C:\xampp\php\PEAR') in C:\xampp\htdocs\xxx\modules\mod_kunenalatest\helper.php on line 9
Warning: require_once(C:\xampp\htdocs\xxx\components\com_kunena\template\default\smile.class.php) [function.require-once]: failed to open stream: No such file or directory in C:\xampp\htdocs\xxx\modules\mod_kunenalatest\helper.php on line 20
Fatal error: require_once() [function.require]: Failed opening required 'C:\xampp\htdocs\xxx\components\com_kunena\template\default\smile.class.php' (include_path='.;C:\xampp\php\PEAR') in C:\xampp\htdocs\xxx\modules\mod_kunenalatest\helper.php on line 20
