Question mit joomla 1.7 und template nicht kompatibel :(
This message contains confidential informationDatabase collation check: The collation of your table fields are correct
This message contains confidential informationhtaccess: Missing | PHP environment: Max execution time: 12 seconds | Max execution memory: 64M | Max file upload: 128MThis message contains confidential informationJoomla default template details : cosmic_lernvid.com | author: Juergen Koller | version: 1.0 | creationdate: 08.06.2009
<div>Check back soon!</div>enablerss 1 enablepdf 1 threads_per_page 20 messages_per_page 6 messages_per_page_search 15 showhistory 1 historylimit 6 shownew 1 jmambot 0 disemoticons 0 template aphotic-II showannouncement 1 avataroncat 0 catimagepath category_images/ showchildcaticon 1 annmodid 62 rtewidth 450 rteheight 300 enableforumjump 1 reportmsg 1 username 1 askemail 0 showemail 0 showuserstats 1 showkarma 1 useredit 1 useredittime 0 useredittimegrace 600 editmarkup 1 allowsubscriptions 1 subscriptionschecked 1 allowfavorites 1 maxsubject 50 maxsig 300 regonly 0 changename 0 pubwrite 0 floodprotection 0 mailmod 0 mailadmin 0 captcha 0 mailfull 1 allowavatar 1 allowavatarupload 1 allowavatargallery 1 avatarquality 65 avatarsize 2048 allowimageupload 0 allowimageregupload 1 imageheight 800 imagewidth 800 imagesize 150 allowfileupload 0 allowfileregupload 1 filetypes txt,rtf,pdf,zip,tar.gz,tgz,tar.bz2 filesize 120 showranking 1 rankimages 1 avatar_src fb fb_profile fb pm_component no userlist_rows 30 userlist_online 1 userlist_avatar 1 userlist_name 1 userlist_username 1 userlist_posts 1 userlist_karma 1 userlist_email 0 userlist_usertype 0 userlist_joindate 1 userlist_lastvisitdate 1 userlist_userhits 1 latestcategory showstats 1 showwhoisonline 1 showgenstats 1 showpopuserstats 1 popusercount 5 showpopsubjectstats 1 popsubjectcount 5 usernamechange 0 rules_infb 1 rules_cid 1 help_infb 1 help_cid 1 showspoilertag 1 showvideotag 1 showebaytag 1 trimlongurls 1 trimlongurlsfront 40 trimlongurlsback 20 autoembedyoutube 1 autoembedebay 1 ebaylanguagecode en-us fbsessiontimeout 1800 highlightcode 0 rss_type topic rss_timelimit month rss_limit 100 rss_included_categories rss_excluded_categories rss_specification rss2.0 rss_allow_html 1 rss_author_format name rss_author_in_title 1 rss_word_count 0 rss_old_titles 1 rss_cache 900 fbdefaultpage recent default_sort asc alphauserpointsnumchars 0 sef 1 sefcats 0 sefutf8 0 showimgforguest 1 showfileforguest 1 pollnboptions 4 pollallowvoteone 1 pollenabled 1 poppollscount 5 showpoppollstats 1 polltimebtvotes 00:15:00 pollnbvotesbyuser 100 pollresultsuserslist 1 maxpersotext 50 ordering_system mesid post_dateformat ago post_dateformat_hover datetime hide_ip 1 js_actstr_integration 0 imagetypes jpg,jpeg,gif,png checkmimetypes 1 imagemimetypes image/jpeg,image/jpg,image/gif,image/png imagequality 50 thumbheight 32 thumbwidth 32 hideuserprofileinfo put_empty integration_access auto integration_login auto integration_avatar auto integration_profile auto integration_private auto integration_activity auto boxghostmessage 0 userdeletetmessage 0 latestcategory_in 1 topicicons 1 onlineusers 1 debug 1 catsautosubscribed 0 showbannedreason 0 version_check 1 showthankyou 1 showpopthankyoustats 1 popthankscount 5 mod_see_deleted 0 bbcode_img_secure text listcat_show_moderators 1 lightbox 1 activity_limit 0 show_list_time 720 show_session_type 0 show_session_starttime 0 userlist_allowed 0 userlist_count_users 1 enable_threaded_layouts 0 category_subscriptions post topic_subscriptions every pubprofile 1 thankyou_max 10 Third-party components: None
Dein Template ist aus dem Jahre 2009 wo glaub 1.2.x aktuell war. Wenn dein Template jetzt selbständig die alte Version ladet überschreibt es die Joomla library, was dazu führt, dass Kunena die funktionen die es braucht nicht findet.
Also müsstest du mal deine Template Dateien öffnen, höchst wahrscheinlich reicht die templates/dein template/index.php um dort zu schauen welche JS Bibs dein Template ladet und diese mal zu deaktivieren/auskommentieren.
Ein vl einfacherer Weg wäre den Template Ersteller zu fragen ob er ein update machen würde ...
Kunena Contributor & Language Coordinator
Kunena Birthday Module | Kunena LaTeX Plugin | SchuWeb Sitemap with free Kunena Plugin
Always up to date with Twitter
Außerdem habe ich gerade auf 1.5 getestet wo es das selbe ist.
Müsste es dann nicht gehen oder braucht das forum eben die bibliothek aus 1.7?
Bin gerade etwas verwirrt.
Bin da auch nich so der profi was joomla angeht. (ist meine erste Website)
Aber es wäre extremst nett von dir wenn du mal einen kurzen Blick auf das Template werfen könntest. Es ist verhältnis mäßig klein. Download: www.lernvid.com/attachments/158_cosmic_lernvid.com.zip
Und an was sehe ich wie und welche version geladen wird?
EDIT: habe etwas gefunden
und zwar ist eine mootools.js file in dem ordner
Und laut diesm code:
Und welche brauche ich jetzt und wo kann ich die laden und paralell zu meinem template laufen lassen?
Somit müsstest du die 1.11 aus deinem template killen und ggf den JavaScript Code deines Templates auf die MT Version 1.3.2 anpassen ...
Müsste ich dann diese mootools.js in meinem template einfach ersetzen oder wie?
Wenn ja durch welche?
Und wird die alte mootools version automatisch wieder geladen wenn ich das im template ändere oder muss ich erst im joomla ornder das auch wieder in ordnung bringen?
Ok du hast recht. Ich hab die mootools.js in meinem template umbenannt. Jetzt geht das forum dafür eben die javascript sachen in meinem template nich mehr
Ich kannte mootools bis jetzt nicht also noch ne dumme frage
was sind die 4 verschiedenen versionen:
s7.directupload.net/images/110807/vlz2943b.png
Da less auch ich nach wenn ich was brauch
Und MT 1.3.2 wird automatisch geladen von J1.7
