Kunena 6.4.8 Released
Please note: The Kunena project team takes NO responsibility for maintaining nor supporting anything in this category.
Solved Userlist showing rank numbers not rank titles
11 years 1 month ago - 11 years 1 month ago #1 by Hoyt
I want my userlist to show ranks, i got it to show rank numbers instead of rank titles (i used the karma setting and display part), what am i doing wrong? the rank numers are the actual good numbers, so i think it has something to do with the selection of the rank name in the database, ... any help is welcome since i'm very new to all of this.
Attatched is the list.php and screenshot of what i have already.
location: /components/com_kunena/template/blue_eagle/html/user/
Last edit: 11 years 1 month ago by Hoyt.
11 years 3 weeks ago - 11 years 3 weeks ago #2 by Hoyt
Finaly got it to work,...:
  • Download the attached file.
  • open the file in notepad, search for "Rang" replace "Rang" for Rank in your desired lang.
  • Rename the file from "list.php_2014-11-19.txt"to "list.php"
  • Upload list.php to: /components/com_kunena/template/blue_eagle/html/user/
  • Set Kunena to show karma in the userlist!
Make sure to backup the list.php file, updating will overwrite the file!
Enjoy!
Last edit: 11 years 3 weeks ago by Hoyt.
The following user(s) said Thank You: Houndy
11 years 3 weeks ago - 11 years 3 weeks ago #3 by Houndy
It isn't fully functional yet, I tested it and only special ranks were shown on the userlist. I'll try to fix it so that normal ranks are shown as well.
Last edit: 11 years 3 weeks ago by Houndy.
11 years 1 week ago #4 by Hoyt
I found out that when a new member is registered, it gets rank 0, but there is no rank 0 defined in the database (numbering starts at 1 and goes up from there), so i changed one of the ranks i am using to id 0 directly in the database, so it is working just fine for me.
11 years 4 days ago #5 by Hoyt
If you are not used to working in databases i would not advice to change it yourselve, if you don't mind not showing a rank when a new user is added, the files added before work just fine. The userlist will start showing the rank after you change the rank of a user in the joomla backend, after that it will show the correct rank.
11 years 4 days ago #6 by Hoyt
It's not just a file to edit, my webhoster uses cpanel to control the backend, i will make a "how to" and post it here in a bit.
11 years 4 days ago - 11 years 4 days ago #7 by Hoyt
Finished,..... i hope you get the job done with this,... i added a step by step tutorial
Last edit: 11 years 4 days ago by Hoyt.
Time to create page: 0.273 seconds
