Kunena 5.1.18 Released (30 Jun 2020)
The Kunena team has announce the arrival of Kunena 5.1.18 [K 5.1.18] which is now available for download as a native Joomla extension for J! 3.9.x. This version addresses most of the issues that were discovered in K 5.1 and issues discovered during the development stages of K 5.1.
Solved Need a solid template —> Blue eagle, Crypsisb3, 9themestore.com, other provider
7 months 1 week ago #1 by Chacapamac
I need a solid template for Kunena, ready to pay.
The free one I have from JoomDev don’t work well anymore.
Whatever I choose, I will probably customize it a lot because I’m really difficult with the design.
I just want stability and the full set of possibility given by the newer Kunena 5.
I was going to buy the Blue Eagle one to help the project...?
I’m not sure if it’s better than Crypsis3 ?
You also have the 9themestore, Joomforest and others? — My experience with Joomdev is not really good...
Any suggestions will be appreciate
7 months 1 week ago #2 by Chacapamac
Well, I finally buy Blue Eagle.
My incentive was the provenance, Kunena itself — Should work properly and the fact that Kunena should be help by the community that use it.
So far, I’m relatively happy, as I was expected lot of css to make it to my taste.
My only problem is the use of some table (row,td...) — kind of last decade code, don’t you think?
7 months 6 days ago #3 by 9themestore
I agree with you, so you can override the category list layout or topic list layout for Blue eagle template.
  • Not Allowed: to reply.
Time to create page: 0.063 seconds
