Kunena 6.2.6 released
Solved Double acces form on Kunena home page
I'm quite a newbie about web designing in Kunena but I have a very important question (for me).
I have a double "access" form on the home page of the Kunena Forum and I don't know how to remove it. For me it is possible to use front-end tools either modifying the css files.
Can anyone help me?
Thanks in advance.
Alessio
- 9themestore
- Premium Member
I think, you should paste your site's url here. We will help you to debug this problem. This is Bootstrap conflict style, so we still need check this problem on your site.
Best regards,
I'm new too and just installed the Kunena Forum on a test-site..
i'm having the same problem : sobanto2.be
Could you help me ?
And I notice that i'm not seeing the login on a mobile phone..
Thx for helping me out..
thanks
Kind regards,
Bart
bartvdm75 wrote: OK, it was a Bootstrap conflict : switch the Load Bootstrap css to 'Yes', although the 'login' is placed a bit high..
A question: where is the Load Bootstrap option?
bartvdm75 wrote: Have you tried another template ? or try to set 'Load Bootstrap' to 'Yes' ?
Kind regards,
Bart
I have tried other templates but got the same layout with two "Access" buttons....
bartvdm75 wrote: In the 'Crypsis' Template i found it in the 'Basic Settings'
I don't use Crypsis Template now but Helix3. I think that Kunena Forum should be independent from the template set.
