Kunena 6.2.6 released
Solved Rsform to Forum post
I have both Kunena v4 and rsform and am looking to have rsform to submit an application to the forums using the mapping plugin that comes with rsforms.
No i have got to a stage where i cannot go any further i have gotten the test form to post to the forum how ever when the post is click i
Access Denied
You do not have permissions to access this page. and need help figuring out the rest the mapping is as follows
i need to know how to add posted time and to get it readable inside the forums
Regards
CprlRst
as i have added the following
and get the following error
Duplicate entry '31' for key 'PRIMARY' SQL=INSERT INTO `#__kunena_messages` SET `id` = '31' , `thread` = '31' , `catid` = '6' , `name` = '627' , `userid` = ',627'
I've never attempted to update the Kunena message tables other than using the standard interface (... well, that's not entirely true because I know my way around the database).
I haven't looked into the 120,000+ lines of code in Kunena to see where the standard interface updates the table.
As I wrote earlier, there are (at least) three tables that need to be updated. There may also be others (e.g. updating posts in _kunena_users). In effect, we're trying to mimic the way database update is performed by Kunena.
I'm guessing that you have extraneous entries in your database and you need to get the three tables back into synch. Perhaps, if you delete some of your test data, get the ids synched, you won't run into those failed attempts to enter a new record with the same primary key as another record that already exists (?)
Access Denied
when trying to view post just wondering what tables need to be adjusted for a post work gotta be missing something simple i believe
Without knowing anything about your website it's almost impossible to help analyse the specific cause of your problem but, in general terms, for a forum post to "work", in MVC terms, there needs to be a view and for the view to work there needs to be a menu item.
johnmaguire.org.uk/index.php/forum/welcome-mat
there you can see test post that gives a you do not have permission to view which seems what the 404 error was being confused with by the site owner.
if you click form from the menu it will show the form thats trying to be added to the forum.
i hope this helps a little
