- Thank you received: 5
Question Subscription Problem
I dont use kunena profile but easy social.
ANd i repeat , all these started after updating the template.
Today i am unsuscrubed from the most of the topics so i will know if i am corect or not.
the box is always checked when i reply,
but in the settings it is not set to be checked.
Now i really need help.
Is there a way not to be checked by default the Subscription box when i reply ?
From the settings is not responding
Is set not to be checked
prntscr.com/awlh4q
This is a new "feature" of K 4.0; I wrote an explanation in Kunena 4.0.5: changed subscribe checkbox “behaviour” angers community .Nikiniko wrote: I still have the problem the box is always checked when I reply, but in the settings it is not set to be checked.
1) Components » Configuration » Users » Subscriptions » Check Subscription Box (as shown in the image below)
is not working for me
2) This is the new arrangement:
Your users will need to edit their Kunena profile. If your forum does not allow users to edit their Kunena profile (for example, if you use Community Builder or JomSocial profiles with your forum) then this procedure will not work.
3) One of the developers posted a hint to help users change this behaviour by running the following SQL command:
UPDATE `#__kunena_users` SET `canSubscribe` = '-1'
where # is your Joomla table prefix.
The above SQL command is untested and may cause corruption or loss of important forum data.
Use at your own risk.
Is there something else i can do ?
Is really bad if you are in a forum to receive 30-40-50 mails per day.
For small forums maybe is ok
I am kunena 4.10
Makes members stop posting.
Or add a new menu item on the forum that's lead to the kunena edit page.
you mean community Builder?
I use easy social nothing in common.
What do you mean with this ?a new menu item on the forum that's lead to the kunena edit page.
Link to Edit Kunena profil ?
Are you sure that this is possible together with easy social profile ?
Parent Item = "Forum" - Access ="Registered" - Add title = "Edit Profile" - save - change ordering - Save again
Thank you again
