Question Problems with the upload button now working - jQuery is not defined
- HardstylerDK
- Topic Author
- Senior Member
But the weird thing is, that I've set almost everyone of the bbcodes to not show, but they show up anyways. :S
- HardstylerDK
- Topic Author
- Senior Member
In the "Configuration" of Kunena this is what I've entered into the "Limit Attachments" box.
How do-you have disabled most of the bbcode icons ?HardstylerDK wrote: Yes i saw that.
You should have these inline javascript code :
- HardstylerDK
- Topic Author
- Senior Member
I've tried disabling them in both the template options, and the kunena component options, but non of them seems to remove these icons/functions.
- HardstylerDK
- Topic Author
- Senior Member
- HardstylerDK
- Topic Author
- Senior Member
This is something generated by KunenaHardstylerDK wrote: Is it something that are generated by Kunena, or Joomla? Cause i haven't touched any files from the Kunena component, plugins or anything related to Kunena.
In this case i need to check in the Crypsis B3 template is the javascript part showed above is right generatedHardstylerDK wrote: As you can see here, I've set everything to not show, but it still shows up, when creating a new topic.
Do-you use Joomla! plugins to combine, minify javascript or which could remove this javascript code ?
- HardstylerDK
- Topic Author
- Senior Member
What would you need, to check the Crypsis B3 template?
- HardstylerDK
- Topic Author
- Senior Member
