- Thank you received: 2
Solved Banner users or deleted users problem - Users think their account is being hacked
- Alphauserpoints
- jomsocial
- Kunena
So go to Alphauserpoints plugin and disable the avatar option, same on the kunena plugin.
just delete the topics so there's no more problem?
Uninstalling Jomsocial makes no user is displayed
Is there a way to delete all the posts without any user attached or with a spammer attached?
make sure you selected all options
Can I have a query to delete all the messages done by an banned user of by a non existant user?
All my users are going crazy thinking that their accounts are hacked.
I HIRED SOMEONE, he told me he couldn't find the answer.
IF someone here is willing to do it for a price, just tell me and the problem is solved. I'll be glad to post the solution for all the kunena users that have the same problem.
regards,
As we all know, it can be disastrous to delete accounts from the Joomla user table — you've already discovered one of the consequences of that action. Some years ago, the Kunena team issued warnings to not delete user accounts. People didn't take that advice and it causes problems. The problems can filter through to JomSocial, AlphaUserPoints and other components that originate from the Joomla user table. What needs to be done is to get everything back into synch.
I will work with you for as long as it takes to fix the problem. Just about knows my business and whether I might be a reliable choice or not; therefore I will leave the matter in your hands to decide what you want to do next.
