Kunena 7.0.2 Released
The Kunena team has announce the arrival of Kunena 7.0.2 [K 7.0.2] in stable which is now available for download as a native Joomla extension for J! 5.3.x/5.4.x/6.0.x. This version addresses most of the issues that were discovered in K 6.2 / K 6.3 / K 6.4 and issues discovered during the last development stages of K 7.0
Topics must relate to a currently supported version of Kunena. If you are unsure what is the current supported version of Kunena, please go to the
download
page.
Question Joomla 6 support?
5 months 3 weeks ago #233939
by xillibit
Replied by xillibit on topic Joomla 6 support?
I can test in the evening, i will make a list of what i have tested. And what is working or not
The following user(s) said Thank You: ruud
5 months 3 weeks ago #233943
by ruud
sharing = caring
Replied by ruud on topic Joomla 6 support?
Also just refactored the plg_content_discuss plugin into a service provider / subscriber interface plugin.
So there is even more that (potentially) needs refactoring, add-on modules and plugins...
sharing = caring
5 months 2 weeks ago #233969
by ruud
sharing = caring
Just a thought: with the level of refactoring and using Events etc. maybe it is a good idea to label 6.5 version 7 instead?
what has been done up until now might impact external plugins. I have no idea how many there are and if they are actively maintained. This version definitely needs more testing then the 'hooray a new version lets update because it always works' way of testing done normally.
Would welcome and love developers to step in here and test / share their use cases. Is there a way to contact them / set this on their agenda?
sharing = caring
5 months 2 weeks ago - 5 months 2 weeks ago #233970
by Leen
With kind regards
Leen
Replied by Leen on topic Joomla 6 support?
Hi, I'm testing Kunena K6.5 locally in 6.0.0-beta4-dev with WAMP.Server
It's working pretty well, but I can't generate a Kunena Configuration Report, and I get this error.
Is this happening to you as well?
An error has occurred.
[quote]0 There is no "chosen" asset of a "preset" type in the registry.[/quote]
Call Stack[b]#[/b][b]Function[/b][b]Location[/b]1()JROOT\libraries\src\WebAsset\WebAssetRegistry.php:1352Joomla\CMS\WebAsset\WebAssetRegistry->get()JROOT\libraries\src\WebAsset\WebAssetManager.php:2743Joomla\CMS\WebAsset\WebAssetManager->useAsset()JROOT\libraries\src\WebAsset\WebAssetManager.php:2084Joomla\CMS\WebAsset\WebAssetManager->__call()JROOT\administrator\components\com_kunena\tmpl\tools\report.php:235include()JROOT\libraries\src\MVC\View\HtmlView.php:4166Joomla\CMS\MVC\View\HtmlView->loadTemplate()JROOT\libraries\src\MVC\View\HtmlView.php:2047Joomla\CMS\MVC\View\HtmlView->display()JROOT\administrator\components\com_kunena\src\View\Tools\HtmlView.php:1818Kunena\Forum\Administrator\View\Tools\HtmlView->display()JROOT\libraries\src\MVC\Controller\BaseController.php:6979Joomla\CMS\MVC\Controller\BaseController->display()JROOT\administrator\components\com_kunena\src\Controller\DisplayController.php:6210Kunena\Forum\Administrator\Controller\DisplayController->display()JROOT\libraries\src\MVC\Controller\BaseController.php:73011Joomla\CMS\MVC\Controller\BaseController->execute()JROOT\libraries\src\Dispatcher\ComponentDispatcher.php:14312Joomla\CMS\Dispatcher\ComponentDispatcher->dispatch()JROOT\libraries\src\Component\ComponentHelper.php:36113Joomla\CMS\Component\ComponentHelper::renderComponent()JROOT\libraries\src\Application\AdministratorApplication.php:15014Joomla\CMS\Application\AdministratorApplication->dispatch()JROOT\libraries\src\Application\AdministratorApplication.php:20515Joomla\CMS\Application\AdministratorApplication->doExecute()JROOT\libraries\src\Application\CMSApplication.php:31516Joomla\CMS\Application\CMSApplication->execute()JROOT\administrator\includes\app.php:5817require_once()
With kind regards
Leen
Last edit: 5 months 2 weeks ago by Leen.
5 months 2 weeks ago #233971
by ruud
sharing = caring
Thanks for reporting Leen >
github.com/Kunena/Kunena-Forum/pull/9912
sharing = caring
5 months 2 weeks ago #233973
by xillibit
It was something i'am thinking too by renaming 6.5 to 7.0 version, by looking in the JED there are couple of plugins : extensions.joomla.org/tags/kunena-extensions/ some are maintained and designed to work on Joomla! 5.x.
Hello,Just a thought: with the level of refactoring and using Events etc. maybe it is a good idea to label 6.5 version 7 instead?
Time to create page: 0.310 seconds
