- Thank you received: 145
Kunena 6.2.6 released
Question Problem with PDF attachments
so I guess it's not open to the public
" Suspicious
This request looks suspicious and has been ignored. Repeated suspicious requests may result in your device being blocked. If you feel this is unjustified please contact webmaster birdlifephotography.org.au and quote '2001:1c03:4304:8900:6915:61bf:3fb3:2db3'.
An error has occurred while processing your request.
You may not be able to visit this page because of:
an out-of-date bookmark/favourite
a mistyped address
a search engine that has an out-of-date listing for this site
you have no access to this page
L.v.d.A
- rob parker
- Topic Author
- Junior Member
- Thank you received: 3
I've attached an image of the post in my Chrome browser, as a guest user . You should be able to see the direct URL in the address bar, so that should help.
Heading for bed - back tomorrow.
now i see the correct forum with attachment
have you tried it with another pdf? and there are no spaces in the filename?
and in Kunena Forum: Configuration>tab uploads>Protect Attachments is set to no ?
L.v.d.A
- rob parker
- Topic Author
- Junior Member
However, the presence of spaces in the pdf filename is the problem. And that's a problem - because we can't control filenames that people may have for their attachments.
It's very odd that this problem exists only for pdf filenames. The other samples on the test site (docx, xlsx, and txt files) all have spaces in the filenames yet work as expected.
the ... is that also part of the file name if you remove those 3 dots does that pdf work? activate your website protection ?
L.v.d.A
- rob parker
- Topic Author
- Junior Member
Except those red miners.pdf
I'm going to think that the file is damaged or incorrectly uploaded, the more so because I don't even inspect file name (numbers and letters only). (as I can see at sample_pdf)
or other way the file itself is somehow secured.
L.v.d.A
I have tested it and have no problems when PDFs contain spaces and protect is disabled. I get only problems hen protect is enabled.The Protect Attachments setting has no effect.
Tested with Chromium, Firefox and Opera.
But if you disable this option, it will not affect already uploaded PDFs. For these files the error remains.
That's right, protected files get a long letter combination instead of the name and file ending.I'm going to think that the file is damaged or incorrectly uploaded, the more so because I don't even inspect file name (numbers and letters only). (as I can see at sample_pdf)
- rob parker
- Topic Author
- Junior Member
Rich's last post seems to have nailed the problem - if protect attachments was on when the file was uploaded, the problem exists for pdf files with spaces in the filename. The second pdf in my test post, added later when protection was off, works as expected, and it has spaces in the filename.
The downloaded file with the cryptic filename is actually a pdf file; if you add ".pdf" to the end of the filename it will open correctly.
I think this behaviour is a bug in Kunena. Do the Kunena developers monitor the forum for issues such as this, or should I report this by some other means?
