Solved Help for newbie. Just installed Kunena
- OldCharlie
- Topic Author
- Junior Member
- OldCharlie
- Topic Author
- Junior Member
See 7thHeaven.cloud
- OldCharlie
- Topic Author
- Junior Member
Here is what I have done, yet I still cannot make it possible for anyone to contribute to this forum. Can you contribute? Go to Lindy Alert
2. You've chosen Review
Review means, an Admin or global moderator must check the user post, and afterwards approve.
You see on my image the correct setting.
Green hook means yes
Red symbol means no
Therefore, you need the red symbol at these options (see image).
- OldCharlie
- Topic Author
- Junior Member
The same applies when you create a new category. It is usually not necessary to change anything unless you want to your needs customized forum.
- OldCharlie
- Topic Author
- Junior Member
Bill
- OldCharlie
- Topic Author
- Junior Member
I set security setting to "Moderate Guests" but how do I know when a guest as submitted a topic or whatever.....?
Go to the Kunena configuration (tab Security) and set Allow Guests to Post/Write = Yes.How do I make it so anyone can create a topic and write to it. I don't want them to have to register.
Additional, you must for each category (tab Category Permissions) to mark Public (see first image).
* Administrators and Moderators get a maiil to this post (it's defaul setting in the configuration (tab Security)I set security setting to "Moderate Guests" but how do I know when a guest as submitted a topic or whatever.....?
* It is displayed on the index page for admins and mods.
* Additional, you can create a Kunena menu item Recent Posts with view Unapproved Posts (image 2).
