Kunena 6.2.6 released
Solved Assign a module for each internal kategory of the forum
I'd like to know if the following is possible:
I need to activate a module with an image in each category of the forum I have created, but when I search for the category that has been created through "kunena categories" it does not appear and therefore I cannot make a module with an image appear only when the user accesses that category.
I thought that somehow it was like the native Joomla menu categories, but I see that Kunena has its own hierarchy.
The idea is to see a different image inserted in a module when the user accesses the different kunena categories.
Any ideas?
But you certainly don't mean that
L.v.d.A
Just as we can assign a module (image) to be displayed in each of the Joomla categories, in this case with the Kunena categories I can't find how to do it.
I tried to create a URL menu with the same address as a Kunena section, but it doesn't allow me to do it.
added and I choose kunena Show category
then I can choose a category under Category ID
if I then choose the link type tab, I can insert a picture
but must make them small eg 50px.
Do you mean that ? maybe it can help you
L.v.d.A
The module can only be seen when you access a forum category, that's the point.
module and also that reads the category icoons but if I do it
well you can add your own category of icons. read more here
L.v.d.A
I thought it was possible to tell in which kunena category you can display or hide a native Joomla module, but I was surprised to see that you can't.
We can only enable or disable a module for Joomla pages, but not for the categories of a section in Kunena, this should be necessary and offer more possibilities for customization in the web environment.
I solved it by creating a new menu for each Kunena category listing, it's the only viable solution.
This way when the user accesses a category in the forum a custom module is activated where images can be inserted to make navigation more intuitive.
Thank you all for your answers.
If you want menu items in other menus which are linked to the categories, then create Systemlinks -> Menu Item Type = Menu Item Alias.
docs.kunena.org/en/troubleshooting/menu-issues
Then it's indifferent whether you choose a category from the index page or accessed via a different menu, it displays always the right module.
