Solved Editing/Disabling Open Graph Meta Tags [SOLVED]
5 years 2 months ago - 5 years 2 months ago #1 by OpenTexts
Hello, I have found a security hole with Open Graph tags.
When I set to show only display names (not logins), they work normally with Kunena. But if I open a page source, I can find there a real login as a meta tag (<meta property="og:author").
How can I completely disable generating this?
Thank you.
Last edit: 5 years 2 months ago by OpenTexts. Reason: Removing a forum report information. Setting a [SOLVED] status.
5 years 2 months ago #2 by ssh
Let's wait for a fix.
in the meanwhile, you can comment the line 453 in /components/com_kunena/controller/topic/item/display.php;
//$this->setMetaData('og:author', $this->topic->getAuthor()->username, 'property');
The following user(s) said Thank You: OpenTexts
5 years 2 months ago #3 by OpenTexts
ssh wrote: Let's wait for a fix.
Thank you! Partially it works. But I have found one more place in that code, which also displays a name:
"@type": "Person", "name": "LOGIN_NAME"
5 years 2 months ago #4 by ruud
Hi, og:author is a non-existing tag and should NOT be used.
see below the information from facebook when using the og:author tag:
sharing = caring
5 years 2 months ago - 5 years 2 months ago #5 by OpenTexts
ruud wrote: Hi, og:author is a non-existing tag and should NOT be used.
I have already disabled this tag as ssh wrote. But this "author" thing is more complicated than I thought before. At this Kunena official forum I don't see this mistake as I see on my site. IDK why.
5 years 2 months ago #6 by OpenTexts
I have found a temporary solution for this issue. As ssh wrote above about a file location, where we can disable Open Graph (site_root/components/com_kunena/controller/topic/item/display.php), we can comment another line to completely block any user login leaking there:
//$tmp->{'name'} = $this->topic->getLastPostAuthor()->username;
Time to create page: 0.482 seconds
