Kunena 6.2.6 released
Solved Load/Display user avatar image inside post
- ante.resetar
- Topic Author
5 years 4 months ago - 5 years 4 months ago #1
by ante.resetar
Load/Display user avatar image inside post was created by ante.resetar
Hi guys. I want to load user avatar image inside the post.
This is my template code inside template/crypsis/layouts/message/item/default.php and it displays created date, edited date, ID and username...
After the username i want to display the user avatar. I'm not very skilled with PHP but i know you are
Thank you
<small class="text-muted pull-right">
<?php if ($this->ipLink && !empty($this->message->ip)) : ?>
<?php echo KunenaIcons::ip(); ?>
<span class="ip"> <?php echo $this->ipLink; ?> </span>
<?php endif; ?>
<?php echo KunenaIcons::clock(); ?>
<?php echo $message->getTime()->toSpan('config_post_dateformat', 'config_post_dateformat_hover'); ?>
<?php if ($message->modified_time) : ?> - <?php echo KunenaIcons::edit() . ' ' . $message->getModifiedTime()->toSpan('config_post_dateformat', 'config_post_dateformat_hover'); endif; ?>
<a href="#<?php echo $this->message->id; ?>" id="<?php echo $this->message->id; ?>"
rel="canonical">#<?php echo $this->numLink; ?></a>
<span class="visible-phone"><?php echo Text::_('COM_KUNENA_BY') . ' ' . $message->getAuthor()->getLink(); ?></span>
</small>
Thank you
Last edit: 5 years 4 months ago by ante.resetar.
- ante.resetar
- Topic Author
5 years 4 months ago #2
by ante.resetar
Replied by ante.resetar on topic Load/Display user avatar image inside post
Any help much appreciated. Thank you
5 years 4 months ago #3
by 810
Replied by 810 on topic Load/Display user avatar image inside post
try:
<?php echo $this->message->getAuthor()->getAvatarImage(KunenaFactory::getTemplate()->params->get('avatarType'), 120);
where 120 is the size.
- ante.resetar
- Topic Author
5 years 4 months ago #4
by ante.resetar
That worked like charm! Mark as solved. Thank you chief!
Time to create page: 0.382 seconds
