- Thank you received: 2427
Question 0 users 0 guests
- romagromov
- Topic Author
- Senior Member
Slacker wrote: Have you controlled the Kunena tables in the database and especially kunena_sessions table? You can do this with phpmyadmin. If kunena-session table is corrupt omline will not work.
Yes. I checked kunena_sessions table. Everything fine.
Download Free Software for Windows absolutly free.
- romagromov
- Topic Author
- Senior Member
I created clean Joomla Site and installed Kunena.
Then I copied DB from problem site to clean site - everything fine, block correct displays online users.
So, issue is not related to Mysql.
Ok, then I copied com_kunena from problem site to clean site - All OK.
So, issue is not related to template or any other files.
Next, I disabled all modules on problem site - still have issue.
Then I disabled all plugins on problem site - still have issue.
So, I'm confused. I don't know how to find reason of problem.
I also found, that besides Online users Kunena does not displays Legend (Site Administrator Global Moderator Moderator Banned User Guest)...
Slacker wrote: Have you checked session life time in Kunena Configuration? I have 1800 seconds. Joomla online shows those who visits Joomla, whereas Kunena online shows those in forum. Checked my site just and half was in the forum.
Have you changed the session live time in Joomla? It must be the same live time. If you change the live time in Joomla, you must adjust the time also in Kunena.romagromov wrote: Sometime everything was fine.
I never changed Kunena settings.
After the next update (I don't know which exact), this data was broken.
hmm.. It seems, you have almost everything tested what is possible. Have you also tried to reinstall Kunena on your live site? Maybe the current installation contain a corrupt file.This is some kind of mysticism...
I createв clean Joomla Site and installed Kunena.
- romagromov
- Topic Author
- Senior Member
It seems yes. I had different Session Lifetime.Have you changed the session live time in Joomla? It must be the same live time. If you change the live time in Joomla, you must adjust the time also in Kunena.
But now I fixed this - but issue is not gone.
Yes. And I already updated and reinstalled Kunena on my site - no results.
- romagromov
- Topic Author
- Senior Member
When Shared Sessions option enabled - Kunena does not displays online users and legend.
Hope you'll fix it.
Probably is this the cause.When enabled, a user's session is shared between the frontend and administrator sections of the site. Note that changing this value will invalidate all existing sessions on the site.
Yes, that's correct, it's no matter if the admin login/logout in the front- or backend. It always applies to both accesses at the same time.Slacker wrote: Shared sessions means that admin is logged in also in frontend. Right?
